Alert if a Service IS running
neworderfac33
Post by neworderfac33 »
Good afternoon,
I created a command in commands.cfg
        command_name    negatepr
        command_line    $USER1$/negate $USER1$/$ARG1$
to allow Nagios to generate an alert if a particular application WAS running, rather than if it wasn't:
#define service{
#        use                      generic-service
#        hostgroup_name           jenkins-test-masters,jenkins-slaves
#       service_description      Alert if running - Notepad
#       check_command            negatepr!check_nt -H $HOSTADDRESS$ -p 12489 -v PROCSTATE -d SHOWALL -l notepad.exe
and this runs fine. Now I want to extend this functionality to alert when a SERVICE is running, but when I use this:
        service_description     Service active - Tomcat7
        check_command           negatepr!check_nt -H $HOSTADDRESS$ -p 12489 - v SERVICESTATE -d SHOWALL -l Tomcat7
the browser returns "check_nt: Could not parse arguments "
Do I need to create a different negate command that will work with services, rather than applications?
[EDIT] - another typo - I had a space between the "-" and the "v" above, although it's not easy to spot. Removed it, restarted and all is fine!
Pete
hsmith
Agent Smith
Re: Alert if a Service IS running
Post by hsmith »
peterooney wrote:Good afternoon,
#define service{
Pete
Ooops. I assume you want me to close this one? :lol:
Former Nagios Employee.
me.
neworderfac33
Incidentally, it DOES work if you set up a dedicated command on commands.cfg
        check_command           TomcatServiceRunning
used in conjunction with:
        command_name    TomcatServiceRunning
        command_line    $USER1$/negate $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v SERVICESTATE -d SHOWALL -l Tomcat7
just in case anyone wants to know how to set up a command relating to a specific service.
Cheers
Pete
neworderfac33
And yes, please - this can be closed - titter ye not! :oops:
