How to monitor Jboss application
lafargeuser
How to monitor Jboss application with XI
Re: How to monitor Jboss application
We have a jboss section on Nagios Exchange. One of those plugins should be able to help you out.lafargeuser wrote:How to monitor Jboss application with XI
Former Nagios Employee.
me.
me.
lafargeuser
Do we have to install agent on jboss server ?
If you read in the instructions on the page of the plugin it will tell you what you need to do. In most cases the plugin is going to go in the Nagios server, some plugins my require and additional component go on the server it is checking.lafargeuser wrote:Do we have to install agent on jboss server ?
me.
me.
lafargeuser
Ok. Here do we have to install agent on jboss or plugin is enough to monitor require data
The one here has a component that you put on both ends. This one has almost 100,000 hits. I would try using this one first.lafargeuser wrote:Ok. Here do we have to install agent on jboss or plugin is enough to monitor require data
me.
me.
lafargeuser
following this url to monitor jboss
http://jboss2nagios.sourceforge.net/
It says Edit your Nagios config to use the check_mbean_collector to monitor any attributes of any MBean.
Using Nagios XI which file should i edit & what please guide
In this case it looks like it is walking you through making a service check for check_mbean_collector. You would want to put the plugin in your /usr/local/nagios/libexec folder,and write a service check and command using Configure ---> Core Config Manager. If you need help with these steps, please let us know.
me.
me.
lafargeuser
using command line I am able to see the output of below command
./check_mbean_collector -H jbosseserver -p port -m java.lang:type=Memory -a NonHeapMemoryUsage -w 10 -c 30
what will be the command & service argument....tried doing but no output. any help really appreciate
Can you please post the service and command definition you created? We can troubleshoot it from there.
me.
me.
