Nagios notification timed out with phyton and yowsup-cli
ferchu22
Post by ferchu22 »
Hello everybody,
I've been working trying to implement Whatsapp notification for Nagios 3.0.6 on my Suse (SUSE Linux Enterprise Server 11 (x86_64), VERSION = 11, PATCHLEVEL = 3).
Test from console is working fine and I receive the whatsapp message; using root, nagios, or nagios + sudo, with any of these lines:
/usr/bin/python /usr/local/bin/yowsup-cli demos -c /usr/local/bin/config -s 5491133334444 "NOTIFICATION.Test"
sudo /usr/bin/python /usr/local/bin/yowsup-cli demos -c /usr/local/bin/config -s 5491133334444 "NOTIFICATION.Test"
but when I configure same line on my service notification command, like this one:
command_line /usr/bin/python /usr/local/bin/yowsup-cli demos -c /usr/local/bin/config -s 5491133334444 "NOTIFICATION.Test"
I receive the timeout message (also setting timeout to 300 seconds):
[1441895110] Warning: Contact 'fpuche' service notification command '/usr/bin/python /usr/local/bin/yowsup-cli demos -c /usr/local/bin/config -s 5491133334444 "NOTIFICATION.Test"' timed out after 30 seconds
I've also tested the same with a .py python sample script, and it worked smoothly. Proxy with nagios and sudo is working properly (configured on /etc/sudoers file).
What may I have to check?
Thanks in advance for your help.
Best regards,
Fernando
jdalrymple
Skynet Drone
Re: Nagios notification timed out with phyton and yowsup-cli
Post by jdalrymple »
selinux or apparmor?
