Changing status of a check_nrpe check
tbmay
Post by tbmay »
Installed Version: 2014R2.7
Centos 6.7
Good morning,
Can I change a check_nrpe check from Critical to Warning?
Regards
hsmith
Agent Smith
Re: Changing status of a check_nrpe check
Post by hsmith »
tbmay wrote:Installed Version: 2014R2.7
Centos 6.7
Good morning,
Regards
What kind of check are you doing? If you see a -w 40 and -c 20 or similar in the service for that check, you could adjust those values accordingly.
Former Nagios Employee.
me.
tbmay
Post by tbmay »
Sorry.
CheckServiceState
No values.
Are you trying to force a particular check into a certain state regardless of what it is currently in? Or are you trying to change the thresholds for that check?
tbmay
Post by tbmay »
I would say the only practical way to deal with this for me is to force all those to be warnings. Since I'm only firing when services are not running that are supposed to be, I don't want to cherry pick. I'd just like this to be WARNING instead of CRITICAL.
ssax
Dreams In Code
Post by ssax »
Ok, the only way that I can see this being possible is to write a wrapper script.
Please post your exact service definition so that I can set it up properly for you, go to Configure > Core Config Manager > Services, find the service and click the little blue disk icon next to it and post it's (sanitized) defintion.
Thank you
tbmay
Post by tbmay »
Understand. No need. I just hoped there was something I didn't know. You can close the ticket.
