Web url monitor with authentication
lafargeuser
Post by lafargeuser »
I have requirement that want to monitor url with authentication. E.g some url have user & passwd
hsmith
Agent Smith
Re: Web url monitor with authentication
Post by hsmith »
lafargeuser wrote:I have requirement that want to monitor url with authentication. E.g some url have user & passwd
Is this basic authentication? If so, check_http can do that. If not, you'll need to find / write a plugin specific to what you are trying to log in to.
Former Nagios Employee.
me.
lafargeuser
Yes. Can you pls provide link to download this plugin
hsmith
Agent Smith
Post by hsmith »
lafargeuser wrote:Yes. Can you pls provide link to download this plugin
Did you install Nagios Plugins when you did your Nagios instillation? If you did, it is in your /usr/local/nagios/libexec directory.
me.
Post by Box293 »
You can use the Website Monitoring wizard to monitor a page with credentials.
Configure Menu > Monitoring Wizard > Website
lafargeuser
Thanks. I shall try that.
hsmith
Agent Smith
Post by hsmith »
lafargeuser wrote:Thanks. I shall try that.
Let us know if you need anymore help with this.
me.
