services checks disable if host is down
vnc786
Post by vnc786 »
hi team,
just wondering is there any system wide settings to disable or suppress active checks if the host is down or unreachable apart from services dependency.
currently i am having 25,000 service checks and 2200 hosts checks.
Nagios XI 2014R2.7
jdalrymple
Skynet Drone
Re: services checks disable if host is down
Post by jdalrymple »
The option isn't there today.
It will arrive with the next major version of XI.
Look under 4.1.0 release notes: https://www.nagios.org/projects/nagios-core/history/4x/
If you want it sooner you can recompile Core and install it on top of the old 4.0.8 code - however if you're a customer with a support agreement we cannot strictly support that configuration.
