oracle monitoring error
lafargeuser
Post by lafargeuser »
CRITICAL - cannot connect to ip:port/sn002050. install_driver(Oracle) failed: Can't locate DBD/Oracle.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/pera
tried following your document but no luck....
hsmith
Agent Smith
Re: oracle monitoring error
Post by hsmith »
Could you link the document that you tried to follow?
Former Nagios Employee.
me.
The document has instructions for resolving that error, can you try it again and see if that fixes it for you?
This is due to the Perl module not being installed properly. To remedy this problem, execute the following from the command line:
export ORACLE_HOME=<path to your Oracle which was given by the script>
export LD_LIBRARY_PATH=$ORACLE_HOME/lib
cpan -i DBD::Oracle
ssax
Dreams In Code
Post by ssax »
From the guide:
cpan -i DBD::Oracle
Did you do this? If so, please post the full output of the cpan command.
kranthi6
Post by kranthi6 »
Hi All,
I apologize for posting here as this is someone's post, but I am having similar issues. I have executed all the steps as mentioned in the document: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Error:
CRITICAL - cannot connect to 142.xx.xxx.xxx:1521/SGRC. install_driver
/usr/lib64/perl5/vendor_perl /usr/share/perl5/
Perhaps the DBD::Oracle perl module hasn't been fully installed,
or perhaps the capitalisation of 'Oracle' isn't right.
Available drivers: DBM, ExampleP, File, Gofer, Proxy, SQLite, Sponge, mysql.
at /usr/local/nagios/libexec/check_oracle_health line 4755
I have also performed the troubleshooting steps provided in the document.
export ORACLE_HOME=/usr/lib/oracle/12.1/client64
cpan -i DBD::Oracle
The snapshot of the error message is below (attached the full output from cpan too)
CPAN error:
Warning: No success on command[/usr/bin/perl Makefile.PL INSTALLDIRS=site]
PYTHIAN/DBD-Oracle-1.74.tar.gz
/usr/bin/perl Makefile.PL INSTALLDIRS=site -- NOT OK
Running make test
Make had some problems, won't test
Running make install
Make had some problems, won't install
Nagios XI version: 5.2.5
Instant Client versions used:
Version 12.1.0.2.0
i. oracle-instantclient12.1-basic-12.1.0.2.0-1.x86_64.rpm
ii.oracle-instantclient12.1-sqlplus-12.1.0.2.0-1.x86_64.rpm
iii.oracle-instantclient12.1-devel-12.1.0.2.0-1.x86_64.rpm
Server Details:
uname -a
Linux testserver1100 2.6.32-431.el6.x86_64 #1 SMP Sun Nov 10 22:19:54 EST 2013 x86_64 x86_64 x86_64 GNU/Linux
# cat /etc/*release*
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
cat: /etc/lsb-release.d: Is a directory
Red Hat Enterprise Linux Server release 6.5 (Santiago)
cpe:/o:redhat:enterprise_linux:6server:ga:server
ssax
Dreams In Code
Post by ssax »
Try this and see if it resolves it for you:
export ORACLE_HOME=/usr/lib/oracle/12.1/client64/lib
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/oracle/12.1/client64/lib/
export PATH=$PATH:/usr/lib/oracle/12.1/client64/bin
cpan -i DBD::Oracle
kranthi6
Post by kranthi6 »
Hi ssax,
You are star! I could complete the installation successfully.
Now I am encountering another error: CRITICAL - cannot connect to xx.xx.xxx.xx:1521/SGRC. ORA-12514: TNS:listener does not currently know of service requested in connect descriptor (DBD ERROR: OCIServerAttach)
Please share your thoughts!
Can you please post the related service definition that the check is using?
kranthi6
Post by kranthi6 »
Hi rkennedy,
Do you mean the service command? Here it is:
check_xi_oracletablespace!--connect 'xxx.xx.xx.xxx:1521/SGRC' --username 'test' --password 'ptest' --mode tablespace-usage --warning 90 --critical 98
Thank you!
