Internal request status?
BanditBBS
Post by BanditBBS »
Hey all, TASK ID 2601. from https://support.nagios.com/forum/viewto ... ata#p95106
Is there a status I could get for that? God I'd kill right now to be able to export in csv the data used to make graphs! I tried using rrdtool to export to an xml and the xml has me so confused!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Internal request status?
The task you referenced has not been assigned and I see no progress made on it, however there were many things added to XI 5 (and previous versions) that were not associated with a specific task, so it is possible it has been added already. I will do some digging and see if it made it in under the radar, but bear in mind XI 5 is still being worked on.
Edit: I don't believe this has made it in as of now.
