TypeError: Cannot read property length of undefined
WillemDH
Post by WillemDH »
Since recently, it could be since the 2.2 upgrade but I'm not sure, I'm seeing errors in some pie graphs:
Nothing really changed in the global config, filters or inputs.
Nagios XI 5.8.1
https://outsideit.net
jolson
Attack Rabbit
Re: TypeError: Cannot read property length of undefined
Post by jolson »
It's very possible that this is related to using HTTPS - try accessing the NLS GUI via HTTP and see if that makes a difference.
After checking on the above, I'd like you to open the developer console of your browser and take a look for any potential 'errors' that pop out at you - they may look something like this:
Though hopefully the errors that you see are more verbose.
Is there anything in the httpd error log?
cat /var/log/httpd/error*
Twits Blog
WillemDH
Post by WillemDH »
Hey Jesse,
Well I'm using HTTP, not HTTPS, so that should not be an issue. I checked the httpd error lof but nothing interesting was in there. The developer console did show a little more info. Please check the attached screenshot.
Grtz
Willem
Nagios XI 5.8.1
jolson
Attack Rabbit
Post by jolson »
The only bug I found on the internet related to this issue is the following:
https://github.com/elastic/kibana/issues/1561
Try going to 'Configure Dashboard' (gear icon in upper right), navigate to the 'Index' tab, and press 'Save'. Is there any difference? What if you modify the index pattern very slightly and then change it back?
For instance:
Change Index Pattern *from* logstash-YYYY.MM.DD *to* stash-YYYY.MM.DD - press save.
Change it back and press 'Save'.
I have asked the developers about the screenshot you sent in - I'm waiting on that response.
Is there any impact in functionality, or is this a visual bug?
Twits Blog
WillemDH
Post by WillemDH »
Nice one Jesse, changing the index pattern, saving and settting it back to the original solved the problem. Thanks. Thread can be closed. It was indeed just a visual bug.
Nagios XI 5.8.1
