I am having dependency failures, I am trying to achieve the following:
1. Create a ping for AD3 (VPN server)
2. test-app-servers to be dependent on ping for Ad3 (VPN SERVER_
3, IF AD3 (VPN SERVER) ping does not to spam email all servers in test-app-servers
ERROR:
Error: Could not find any host matching 'test-app-servers' (config file '/usr/local/nagios/etc/config/servicedepend/service-dependencies.cfg', starting on line 1)
Error: Could not find a service matching host name 'ad3.corp.globoforce.com' and description 'PING-AD3' (config file '/usr/local/nagios/etc/config/servicedepend/service-dependencies.cfg', starting on line 1)
Error: Could not expand master service(s) (config file '/usr/local/nagios/etc/config/servicedepend/service-dependencies.cfg', starting at line 1)
Error: Could not expand dependent service(s) (at config file '/usr/local/nagios/etc/config/servicedepend/service-dependencies.cfg', starting
CONFIG:
define servicedependency {
dependent_hostgroup_name ping-ad3
dependent_service_description PING-AD3
host_name test-app-servers
service_description TEST-APP-SERVERS
execution_failure_criteria w,u,c,p
notification_failure_criteria w,u,c
dependency_period 24x7
/usr/local/nagios/etc/objects/windows/ad3.cfg
define host
use generic-host
host_name ad3.corp.mydomain.com
hostgroups ping-ad3
/usr/local/nagios/etc/config/services/pingvpn.cfg
use local-service
hostgroup_name test-app-servers
check_command check_ping!1000.0,33%!1500.0,66%
/usr/local/nagios/etc/objects/testservers/test-appservers.cfg
define host {
use testenv_generic-vm-host
host_name test-app2-01.corp.mydomain.com
hostgroups test-app-servers
