Checking for minimum bandwidth on switch port
jlmoldan
Post by jlmoldan »
the check_rrdtraf works great on cisco switches for detecting and alertign for Max bandwidth thresholds - however, is there any way to watch for low thresholds?
i.e. if a link goes below X value? I tried a couple of basic things like -4 and have been searching for a possible other check to address this but have been unsuccessful thus far.
Thanks for any ideas.
Re: Checking for minimum bandwidth on switch port
Take a look at this link that describes what you are trying to do.
https://support.nagios.com/forum/viewto ... ld#p140156
jlmoldan
Post by jlmoldan »
Thanks, that looks like it will work!
hsmith
Agent Smith
Post by hsmith »
Is there anything else we can help you out with?
Former Nagios Employee.
me.
