How do I get this plugin to work in XI?
I downloaded the WSF file, modified and tested the script. It works great. What do I need to do in XI?
https://exchange.nagios.org/directory/P ... ns/details
check_number_of_citrix_sessions
hillhealthcenter
Thanks so much,
Tom
Tom
jdalrymple
- Skynet Drone
Re: check_number_of_citrix_sessions
High level
NSCP on your Presentation server you're running the script on
Set up an external command definition in nsclient.ini for the script
Set up a service on the Nagios server to run that external script
Low level...
This could get complicated. Let's start by asking if you've successfully run the script on a PS and gotten useful output?
Low level...
