All,
I'm tryign to install the PERL SDK but am getting the below error when I say yes to the Install; I'm on the free 60 day trial so that I canshow it to work and get it paid for but I need to get it to monitor an ESXi host which the PERL is required for.
Do you accept? (yes/no) y
Thank you.
Network is unavailable, please configure the network first otherwise please
install the following modules manually for use by vSphere CLI:
Archive::Zip 1.20 or newer
Class::MethodMaker 2.10 or newer
UUID 0.03 or newer
Data::Dump 1.15 or newer
SOAP::Lite 0.710.08 or newer
XML::SAX 0.16 or newer
XML::NamespaceSupport 1.09 or newer
XML::LibXML::Common 0.13 or newer
XML::LibXML 1.63 or newer
Perl SDK installation Issue
Re: Perl SDK installation Issue
yanmouddy,
I just posted a rewritten doc for the Nagios XI VMware monitoring, can you please follow the doc from the top and see if it fixes your issues?
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
Nicholas Scott
