Load all configs in a directory
amprantino
Post by amprantino »
Hello all,
is it possible to load all cfg files under a directory?
The obvious addition in nagios.cfg is not working:
cfg_file=/etc/nagios/objects/hostextinfo/*.cfg
Any workaround?
Thank you
alex.mullen
Re: Load all configs in a directory
Post by alex.mullen »
You should change cfg_file to cfg_dir
cfg_dir=/etc/nagios/objects/hostextinfo/
alex.mullen
hsmith
Agent Smith
Post by hsmith »
@amprantino, did that solve your issue or is there something we can do to further help with this?
Thanks @alex.mullen!
Former Nagios Employee.
me.
amprantino
Everything OK!!
Thank you
