Nagios 4.1.2 beta Host pending
Hello, I noticed when I add new host in nagios all services checked on it well, but host state remains in PENDING state even I re-schedule new host check manually. I cannot undertand why. May be the reason is the hosts included in multiple groups...
Re: Nagios 4.1.2 Host pending
Here is (https://github.com/NagiosEnterprises/na ... 4.1.2-beta) beta version witch I using for new statusmap testinng (https://support.nagios.com/forum/viewto ... &start=110).rhassing wrote:Nagios 4.1.2 is not released yet?
jdalrymple
- Skynet Drone
Re: Nagios 4.1.2 beta Host pending
Usually when a host is stuck in pending it's because there is no check_command for that host defined.
Can you verify - perhaps the best place to do so would be objects.cache.
Thek you for your advice. I guess easier way to chek it is visit Configuration menu in the GUI.
You are right indeed check_command was not connected with generic-host template that I use for generic-firewall template.
Fixed.
Fixed.
