On the dashboard I see the abnormal graph in red and when I click on view problems I do not see any data under Top 5 talkers. I am unsure what it is trying to show me because the traffic doesn't look abnormal to me. What data is suppose to show when I click view problems?
View Problem not Working
jdalrymple
- Skynet Drone
Re: View Problem not Working
Perhaps you had no traffic during that timeperiod, and that's abnormal?
Abnormal behavior just identifies traffic patterns over a timeperiod that seriously deviate from normal traffic. If you normally are always shredding along at 10Gbps and traffic stops for a half hour - that would be abnormal.
