How to graph the data collected by check_bind.sh?
I need to be able to take the data collected by the check_bind.sh plugin and graph it so that it can be viewed from the nagios server itself or perhaps by setting up a web front end on the DNS server. I noticed that there is a check_bind.php file that came with the plugin. I am assuming that is used for this purpose. How do most people go about accomplishing this and is there documentation on the process?
jdalrymple
- Skynet Drone
Re: How to graph the data collected by check_bind.sh?
That is a pnp4nagios template:
https://docs.pnp4nagios.org/pnp-0.6/tpl
/usr/local/nagios/share/pnp/templates is the templates directory on our XI installs
Thanks but I'm going to need a little more help on this. Looking at the link you provided where is this "check_conmmand" that determines which template to use?
The link also gives an example of the "HTTP" service and goes on to talk about an XML file that is created automatically. I have no XML files that I can find that map to the check_bind function. Looking at one of the docs in the pnp4nagios folder it says pnp4nagios must be installed however it looks like it may have already been installed.
Could use a lot of help on this one:)
- Box293
- Too Basu
All of the answers to these questions are answered in this talk I did at the Nagios World Conference:
https://www.youtube.com/watch?v=kqA2KcpUFg4
Thanks that's a great video BTW. I think I have enough understanding to go from here. If I get stuck or need to post back I will. Thanks again!
Also, if you don't mind could you weigh in on another problem I am having?
https://support.nagios.com/forum/viewto ... 38#p153738
We're constantly patrolling the forums, so we're definitely aware of your other thread. If you have updates related to the current issue being dealt with in this thread, please feel free to post back here.
Yes, we can close out this thread. If I need further assistance down the road on this topic I will open a new thread.
