Could not stat() command file '/usr/local/nagios/var/rw/nagi
I am getting the following error. I am running Centos7 and Core 4.1.1.
Error: Could not stat() command file '/usr/local/nagios/var/rw/nagios.cmd'!
The external command file may be missing, Nagios may not be running, and/or Nagios may not be checking external commands.
An error occurred while attempting to commit your command for processing.
The searching I have done has said it is a permissions error. I tried a few items but no luck what so ever. Can someone point me in the correct direction
thanks
Jerry
thanks
Jerry
Re: Could not stat() command file '/usr/local/nagios/var/rw/
Hi Jerry,
Can we please get the output of the following?
Check SELinux status:
Check the status of the service:
Check the configuration for errors:
Permissions:
Check log:
Check groups:
getenforceCode: Select all
systemctl status nagiosCode: Select all
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgCode: Select all
ls -l /usr/local/nagios/var
ls -l /usr/local/nagios/var/rwCode: Select all
tail /usr/local/nagios/var/nagios.logCode: Select all
grep nag /etc/groupFormer Nagios Employee.
me.
me.
Hello
Thanks for the reply. I uploaded a file to answer commands you gave me to issue.
thanks again
Jerry
thanks again
Jerry
nagios.txt- (5.65 KiB) Downloaded 588 times
Can you disable SELinux and see if this changes anything?
Also, run these commands please:
setenforce 0Code: Select all
usermod -G nagios nagios
usermod -G nagcmd apache
me.
me.
Just after I posted the attachment . I read another article about changing the mode saying
The problem with this issue is definitely with SELinux, if you temporarily set it to permissive mode, all external commands work well
So I did it using the command you just sent. Also I changed the rights on the Nagios.cmd to 666.
It works. But When I reboot the files change back to 660 and it stops working once again. Does this make any sense
What is the output of a umask command?
me.
me.
in that directory I ran Umask
It replys
0022
It replys
0022
That's the output we want. Could we edit SELinux to not start upon boot?
Change SELINUX=permissive to SELINUX=disabled and reboot.
See if this fixes the issue.
vi /etc/selinux/configSee if this fixes the issue.
me.
me.
That did it!!! I rebooted a few time and we are good. Thanks for all you time and help
take care
Jerry
take care
Jerry
I'm glad we resolved it. SELinux is kind of a bully sometimes. I'll mark this one resolved and close it. Please let us know if there is anything else we can help you with.
me.
me.
