How to generate report NAGIOS avaliability - thisyear
jackadamantina
Post by jackadamantina »
In my nagios I have /usr/local/nagios/var/archive all files this year.
I can not generate the report using all these files. Because? I need to generate the availability report of my hostgroups since the beginning of the year. What I realized is that if you run 2 in 2 months , it shows the result until March (ie the last 6 months).
Re: How to generate report NAGIOS avaliability - thisyear
What version of Nagios Core are you running?
Have you tried to select "Custom Report Period" and select the dates you want for the report?
