Nagios log server installation issues
harsha436
Post by harsha436 »
I downloaded "nagioslogserver-2015r2.2.tar.gz" and tried "./fullinstall". Got below error:
Downloading/unpacking pip
Cannot fetch index base URL https://pypi.python.org/simple/
Could not find any downloads that satisfy the requirement pip
Cleaning up...
No distributions at all found for pip
Storing debug log for failure in /root/.pip/pip.log
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Looks like its not able to fetch the URL. Is there a option to pass "--no-proxy --no-check-certificate" to "python get-pip.py"?
#cat /root/.pip/pip.log
get-pip.py run on Wed Sep 23 16:14:14 2015
Getting page https://pypi.python.org/simple/pip/
Could not fetch URL https://pypi.python.org/simple/pip/: connection error: ('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Authentication Required ( The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied. )',))
Will skip URL https://pypi.python.org/simple/pip/ when looking for download links for pip
===CUT some URL's====
Cleaning up...
Removing temporary dir /tmp/pip_build_root...
Exception information:
Traceback (most recent call last):
File "/tmp/tmpMg46te/pip.zip/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/tmp/tmpMg46te/pip.zip/pip/commands/install.py", line 278, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/tmp/tmpMg46te/pip.zip/pip/req.py", line 1177, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File "/tmp/tmpMg46te/pip.zip/pip/index.py", line 277, in find_requirement
raise DistributionNotFound('No distributions at all found for %s' % req)
DistributionNotFound: No distributions at all found for pip
harsha436
Re: Nagios log server installation issues
Post by harsha436 »
I am running this on "Red Hat Enterprise Linux Server release 6.4" server and there are no applications running in this server.
harsha436
Post by harsha436 »
I have fixed this by "unset https_proxy"
jolson
Attack Rabbit
Post by jolson »
I'm happy to hear that you fixed the issue - am I okay to close this thread?
Twits Blog
harsha436
Post by harsha436 »
Yes, please close this thread. I have just finished the installation, I am sure i will have some more questions later when i start configuring the same :)
