Dear All,
Need help monitoring the radius server with following command
/bin/echo "User-Name=user,Password=pass, NAS-Port-Type = Wireless-802.11" | /usr/bin/radclient $HOSTADDRESS:1812 auth secret
This command works for me perfectly if i execute it with required details. Need to know if the same can be used through nagios also.
Thanks in advance
Vikram
Custom Command
Re: Custom Command
I managed to write it thanks anyway
Re: Custom Command
Glad you found a resolution to your problem.
Nicholas Scott
