checking for socklen_t... yes
checking for type of socket size... size_t
checking for SSL headers... configure: error: Cannot find ssl headers
Subcomponents installation failed - exiting
+ '[' 0 -ne 0 ']'
+ echo 'A-subcomponents appears to have already completed successfully. Moving on to the next step.'
+ tee -a log/A-subcomponents.log
+ echo 'Starting NRPE Agent'
Starting NRPE Agent
+ launchctl start org.nagios.nrpe
++ date +%s
+ log_tarball_name=logs-all-steps-1443106068.tar.gz
+ tar -czf logs-all-steps-1443106068.tar.gz log/
+ cat
I'm in the process of trying to get this installed on my personal MBP, but I have to download xcode first, which happens to be 4GB . I'll post an update when I have confirmed the test results. Thanks!
checking for SSL headers... SSL headers found in /usr
checking for SSL libraries... SSL libraries found in /usr/lib
*** Generating DH Parameters for SSL/TLS ***
Generating DH parameters, 512 bit long safe prime, generator 2
This is going to take a long time
