Parsing 12 hour format timestamps
CFT6Server
Post by CFT6Server »
Seeking some guidance here on how to parse and create a grok pattern/filter for AD DNS debugging logs. The time format is in a 12hour time format and I am not sure not to convert this for proper timestamp due to the AM/PM.
Sample line.
9/24/2015 11:23:52 AM 0F1C PACKET 00000000031A1170 UDP Rcv 172.26.250.44 69d4 Q [0001 D NOERROR] PTR (2)22(3)128(2)75(2)10(7)in-addr(4)arpa(0)
I need to get the time 11:23:52 AM converted to something that can be used as timestamp.
jolson
Attack Rabbit
Re: Parsing 12 hour format timestamps
Post by jolson »
The date filter is capable of recognizing 12-hour timestamps.
https://www.elastic.co/guide/en/logstas ... -date.html
You can match the date filter against any format supplied by the JODA library, which includes 12-hour timestamps. You might try something like this:
date {
match => [ "datefield", "M/DD/YYYY hh.mm.ss a" ]
Give the above a shot and let me know if it works!
Twits Blog
CFT6Server
This is assuming I can grab the whole date into a field?
I am looking how to capture 9/24/2015 11:23:52 AM into a field with grok. I can grab everything except for the AM|PM. I must be missing something minor.
Grok pattern I am trying to use:
%{DATE_US} %{TIME} (?:AM|PM)
lgroschen
Post by lgroschen »
Looks good in the debugger:
  "DATE_US": [
      "9/24/2015"
  "MONTHNUM": [
      "9"
  "MONTHDAY": [
      "24"
  "YEAR": [
      "2015"
  "TIME": [
      "11:23:52"
  "HOUR": [
      "11"
  "MINUTE": [
      "23"
  "SECOND": [
      "52"
/Luke
CFT6Server
what will be the field name that it is parsing? Time? But time doesn't include AM/PM so how will it read the field? In the Elasticsearch example assumes there's a field logdate, but how would put this all in one field for it to add? or that's not how it works?
jolson
Attack Rabbit
Post by jolson »
The easiest way that I can think of approaching this problem is as follows.
1. Get your timestamp into a field called '12_time'
2. Convert the 12_time field into a datestamp.
3. Wipe the '12_time' field appropriately.
The filter:
filter {
 grok {
 match => [ "message", "%{DATE} %{GREEDYDATA:12_time},%{GREEDYDATA:otherdata}" ]
 date {
 match => [ "12_time", "hh:mm:ss a" ]
 target => "12_time"
 timezone => "+00:00"
 grok {
 match => { "12_time" => "%{GREEDYDATA} %{GREEDYDATA:time} " }
 overwrite => [ "12_time" ]
Let me know if the above works for you. Thanks!
Twits Blog
CFT6Server
So this is what I've done instead. There's no punctuation so it makes it a bit harder to grab the time fields. Here's the grok pattern:
Message:
Grok Pattern:
grok {
        match => [ 'message', '%{DATE_US:date} %{TIME:time1} %{WORD:time2} %{WORD:dns_thread_id} %{WORD:dns_context}%{SPACE}%{WORD:dns_packet_id} %{WORD:protocol} %{WORD:dns_direction} %{IP:src_IP}%{SPACE}%{WORD:dns_xid}%{SPACE}(?:Q|R Q|R U|U)%{SPACE}\[%{WORD:dns_hex_flags}%{SPACE}%{WORD:dns_hex_flags}%{SPACE}%{GREEDYDATA:dns_response}\]%{SPACE}%{WORD:dns_recordtype}%{SPACE}%{GREEDYDATA:dns_query_name}']
Now take time1/2 to form the 12h format along with the date
mutate {
	    add_field => { "12time" => "%{date};%{time1} %{time2}" }
	date {
		match => [ "12time", "MM/dd/YYYY;hh:mm:ss a" ]
	mutate {
		remove_field => [ "date","time1",time2" ]
Without the date, it cannot replace the timestamp field and will error and cause logstash to just dump the log entries.
here's the result of this:
The message was 10/6/2015 9:50:34 AM 0C54 PACKET 000000001DD19210 UDP Snd ..............
jolson
Attack Rabbit
Post by jolson »
Well done! This looks proper to me - it looks like your timestamps differ, but that's because the @timestamp field can be displayed in UTC (which is looks like it is, in your case). Do you have any further questions?
Twits Blog
