Trends doesn't show anything
xerez
Post by xerez »
Hi, when i try to see these features, it doesn't show anything. For example, I select "Service", "CPU Load" and "Last 24 Hours", but the graph is empty. Why?
Also, if I access to "Trends" in "Reports", I can't select the host, only appear "-- Select Host --", and in the right corner I see this message:
Warning: Monitoring process may not be running!
Click here for more info.
When I click in "here", it doesn't anything.
What happen? Thanks.
hsmith
Agent Smith
Re: Trends doesn't show anything
Post by hsmith »
Hello xerez,
What version of core are you running? Is it a language other than English by chance?
Former Nagios Employee.
me.
xerez
Post by xerez »
I don't know what happened, but today is working.
Thanks.
hsmith
Agent Smith
Post by hsmith »
I'll leave this one open for now, let us know if you need anything else.
Thanks!
me.
hoodka
Post by hoodka »
I have the same problem but I do not see the choice of the Device / Service nothing. Screenshot in attachment. Where is the problem?
This will happen when your nagios process isn't running. You'll need to start the process in order for the Host field to populate.
