Dear all,
I am wondering if i can monitor web login of some applications i am running like zimbra, moodle. Please advice if any plugin for it.
Thanks and regards
Vikram
how to Check web logins
Re: how to Check web logins
You can do this using the Web Transaction wizard. The wizard uses WebInject and you should be familiar with the format that tool uses (the wizard will also direct you to the appropriate documentation).
Thank you very much for help
