HELP No lock file found in /usr/local/nagios/var/nagios.lock
kevin02081
Post by kevin02081 »
not sure what went wrong.. i log into NagiosXI and get this error..
any ideas on how to fix ?
Re: HELP No lock file found in /usr/local/nagios/var/nagios.
What is the Nagios XI version that you are currently running? Have you tried starting nagios from the web UI by clicking on the actions button next to the "Monitoring Engine" or from the command line by running "service nagios start"?
