Nagios to client communication
jyoti22
Post by jyoti22 »
Nagios management server communicate with windows clients using port 12489. However would like to know the ideal scenario, wether windows client communicates with Nagios management server and if communicates then which port is used for this communication. Thanks.
WillemDH
Re: Nagios to client communication
Post by WillemDH »
Hello jyoti22,
I suggest you read through this:
http://docs.nsclient.org/manual/installing.html
You should also open port 5666 for NRPE and 5667 for NSCA. Port 12489 is used for check_nt.
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
jyoti22
Did WillemDH answer help you out in your question?
Thanks WillemDH for the help.
jyoti22
Post by jyoti22 »
Yes. Thanks.
