check_rrdtraf measure Percentages
glitchcowboy
Post by glitchcowboy »
I had the same desire/issue as https://support.nagios.com/forum/viewto ... 16&t=33828
My solution (from a support recommendation) was to modify the script.
After configuration, put the max bandwidth in ARG5 and modify the check_command to add a '-a $ARG5$'
Here's my mod:
#!/bin/sh
# CHECK_RRDTRAF plugin for Nagios
# Written by Garry W. Cook <[email protected]>
# and Israel Brewster <[email protected]>
# Description:
# This plugin will read the current value from an rrd file and compare with
# warning and critical values, for inbound and outbound bandwidth parameters.
# It will also optionally check the age of the rrd file and warn if
# the file is older than a specified limit.
#  Notes:
#   - This plugin requires:
#       rrdtool
#       awk
#   sed
# Example checkcommands.cfg entry:
# 'check_rrdtraf' command definition
# define command{
#       command_name    check_rrdtraf
#       command_line    $USER1$/check_rrdtraf -f $ARG1$ -c $ARG2$ -w $ARG3$ [-e $ARG4$] [-l $ARG5$] [-a $ARG6$]
# Edit the following variables to match your system.
# You may need to edit the path variable below to include the location
# your rrdtool binary is installed in
RRDTOOLPATH=`echo /usr/local/rrdtool*/bin | awk '{for(i=1;i<=NF;i++) printf(":%s",$i)}'`
PATH=$PATH:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin$RRDTOOLPATH
# Optional Config
# Set the traffic calculation precision (# of decimals)
SCALE=2
# Nothing to change below this line (hopefully)
OSTYPE=`uname -s`
if [ $OSTYPE = "Linux" ]
then
    STATFLAGS='-c %Y'
else
    STATFLAGS='-f %m'
fi
PROGNAME=`basename $0`
PROGPATH=`echo $0 | sed -e 's,[\\/][^\\/][^\\/]*$,,'`
REVISION='0.5'
. $PROGPATH/utils.sh
print_usage() {
        echo ""
        echo "Usage:"
        echo " $PROGNAME -f <rrd_file> -w <warning_pair> -c <critical_pair>"
    echo "           [-v][-e expire_seconds] [-l label_units] [-a int_speed]"
        echo " $PROGNAME (-V | --version)"
        echo " $PROGNAME (-h | --help)"
        echo " "
    echo "Options:"
    echo "-h, --help"
    echo "  Print detaiiled help screen"
    echo "-V, --version"
    echo "  Print version information"
    echo "-v    Verbose output. Can be specified twice for more verbosity"
    echo "-vv   More verbose output, same as -v -v"
    echo "-f    Full path to RRD file to read data from"
    echo "-w    Warning threshold <rate> or pair <incoming>,<outgoing>"
    echo "-c    Critical threshold <rate> or pair <incoming>,<outgoing>"
    echo "-e    Log age threshold (in seconds, 5min=300)"
    echo "-l    Data display label, one of B,K,M or G"
    echo "-a	Interface Speed"
    echo ""
    echo "Notes:"
        echo "-Warning and critical thresholds are MAX values,"
        echo " going above the threshold will trigger an alert."
        echo "-Labels and units for warning and critical values"
        echo " are determined by the -l argument (if specified):"
        echo " B=bps; K=Kbps; M=Mbps; G=Gbps"
    echo "-If the -l switch is specified, input values are assumed to"
    echo " be in the same units as specified in the -l switch"
    echo "-If the -l switch is not specified, output values are scaled"
    echo " appropriately, and input values are assumed to be in Kbps"
        echo ""
print_help() {
        print_version
        print_usage
        echo "Nagios Plugin: Check Bandwidth within an RRD."
        echo ""
        support
    echo "You may also contact the developer of this plug-in directly"
    echo "at [email protected]"
print_version() {
    echo "$PROGNAME v$REVISION"
set_label(){
case $2 in
    B | b)
        LABEL="B"
        DIV="1"
    K | k)
        LABEL="K"
        DIV="1000"
    M | m)
        LABEL="M"
        DIV="1000000"
    G | g)
        LABEL="G"
        DIV="1000000000"
        echo "$2 not a valid Label/Multiplier"
        exit $STATE_UNKNOWN
esac
exitstatus=$STATE_UNKNOWN #default
MAXAGE=0
FILEAGE=0
VERBOSITY=0
LC_NUMERIC="en_US.UTF-8"
# Check for --help, etc.
case $1 in
    -V|--version)
        print_version
        exit $STATE_UNKNOWN
    -h|--help)
        print_help
        exit $STATE_UNKNOWN
esac
# Verify correct number of arguments
if [ $# -lt 6 ]; then
    print_usage
    exit $STATE_UNKNOWN
fi
while [ $# -gt 0 ];do
    case $1 in
    -f)
        FILE=$2
        shift
    -c)
        CRITICAL=$2
        shift
    -w)
        WARNING=$2
        shift
    -e)
        MAXAGE=$2
        shift
    -l)
        set_label $1 $2
        shift
    -a)
	INTSPEED=$2
	shift
    -V|--version)
        print_version
        exit $STATE_UNKNOWN
    -v)
    VERBOSITY=$(($VERBOSITY+1))
    -vv)
    VERBOSITY=2
        echo "$1 is not a recognized option!"
        print_usage
        exit $STATE_UNKNOWN
    esac
    shift
done
if [ $VERBOSITY -gt 0 ]; then
    echo "Using RRD file: $FILE"
fi
#Seperate input warning level and output warning level
INWARN=${WARNING%,*}
OUTWARN=${WARNING#*,}
if [ $VERBOSITY -gt 1 ]; then
    echo "Input warning level(${LABEL:-k}b/s): $INWARN"
    echo "Output warning level(${LABEL:-k}b/s): $OUTWARN"
fi
#Seperate input critical level and output critical level
INCRIT=${CRITICAL%,*}
OUTCRIT=${CRITICAL#*,}
    echo "Input critical level (${LABEL:-k}b/s): $INCRIT"
    echo "Output critical level (${LABEL:-k}b/s): $OUTCRIT"
fi
# Verify file exists and calculate current inbound or outbound bandwidth
if [ -e "$FILE" ]; then
        echo "Fetching data with command: rrdtool fetch $FILE AVERAGE -s-10minutes | grep -vi \"nan\""
    fi
    DATASET=`rrdtool fetch $FILE AVERAGE -s-10minutes| grep -vi "nan"`
    echo "RRD File Data:"
    echo "$DATASET"
    fi
    VALUEIN=`echo "$DATASET" | awk '{x=$2} END { printf("%f\n", x * 8) }'`
    VALUEOUT=`echo "$DATASET" | awk '{x=$3} END { printf("%f\n", x * 8) }'`
    echo "Raw Input Traffic Value (b/s): $VALUEIN"
        echo "Raw Output Traffic Value (b/s): $VALUEOUT"
    fi
    DVALUEIN=${VALUEIN%.*}
    DVALUEOUT=${VALUEOUT%.*}
    echo "Decimal Input Traffic Value (b/s): $DVALUEIN"
    echo "Decimal Output Traffic Value (b/s): $DVALUEOUT"
    fi
# if DIV is not set (no label was given on the command line)
# we figure the best label to use
     if [ ! $DIV ]; then
    #figure label for inbound traffic
    if [ ${VALUEIN%.*} -le 1000 ]; then
        SDIVIN=1
        SLABELIN=""
    elif [ $DVALUEIN -gt 1000 -a $DVALUEIN -le 1000000 ]; then
        SDIVIN=1000
        SLABELIN="K"
    elif [ $DVALUEIN -gt 1000000 -a $DVALUEIN -le 1000000000 ]; then
        SDIVIN=1000000
        SLABELIN="M"
    else
        SDIVIN=1000000000
        SLABELIN="G"
    fi
    #figure label for outbound traffic
    if [ $DVALUEOUT -le 1000 ]; then
            SDIVOUT=1
            SLABELOUT=""
        elif [ $DVALUEOUT -gt 1000 -a $DVALUEOUT -le 1000000 ]; then
            SDIVOUT=1000
            SLABELOUT="K"
        elif [ $DVALUEOUT -gt 1000000 -a $DVALUEOUT -le 1000000000 ]; then
            SDIVOUT=1000000
            SLABELOUT="M"
        else
            SDIVOUT=1000000000
            SLABELOUT="G"
        fi
    else
        SDIVIN=$DIV
        SDIVOUT=$DIV
        SLABELIN=$LABEL
        SLABELOUT=$LABEL
    fi
    echo "Traffic IN scalar: $SDIVIN"
    echo "Traffic OUT scalar: $SDIVOUT"
    fi
    if [ $MAXAGE -ne 0 ]; then
        echo "Determining file age using command: stat $STATFLAGS $FILE"
    fi
    MODTIME=`stat $STATFLAGS $FILE`
    CURTIME=`date +%s`
    FILEAGE=`expr $CURTIME - $MODTIME`
        echo "File $FILE age (s): $FILEAGE"
    fi
    fi
    MVALUEIN=$(bc <<< "scale=${SCALE}; ${DVALUEIN}/${DIV:-1024}")
    MVALUEOUT=$(bc <<< "scale=${SCALE}; ${DVALUEOUT}/${DIV:-1024}")
    if [ $FILEAGE -gt $MAXAGE ]; then
    	echo "WARNING - MRTG log file is older than maximum allowed threshold"
    	exit $STATE_WARNING
    elif [ $(bc <<< "scale=${SCALE}; ${MVALUEIN} >= $INCRIT") -eq 1 -o $(bc <<< "scale=${SCALE}; $MVALUEOUT >= $OUTCRIT") -eq 1 ]; then
        echo -n "CRITICAL - Current BW in: $(echo "scale=$SCALE; ($VALUEIN/$SDIVIN)"| bc)"$SLABELIN"bps Out: $(echo "scale=$SCALE; ($VALUEOUT/$SDIVOUT)"| bc)"$SLABELOUT"bps"
    	INVAL=$(echo "scale=6; ($VALUEIN/$SDIVIN)"| bc)
    	INPCT=$(echo "scale=6; ($VALUEIN/$SDIVIN/$INTSPEED*100)"| bc)
    	OUTVAL=$(echo "scale=6; ($VALUEOUT/$SDIVOUT)"| bc)
    	OUTPCT=$(echo "scale=6; ($VALUEOUT/$SDIVOUT/$INTSPEED*100)"| bc)
	echo -n "|in=${INVAL}$SLABELIN""b/s;$INWARN;$INCRIT; inpct=$INPCT "
        echo "out=${OUTVAL}$SLABELOUT""b/s;$OUTWARN;$OUTCRIT; outpct=$OUTPCT"
        exit $STATE_CRITICAL
    elif [ $(bc <<< "scale=${SCALE}; $MVALUEIN >= $INWARN") -eq 1 -o $(bc <<< "scale=${SCALE}; $MVALUEOUT >= $OUTWARN") -eq 1 ]; then
        echo -n "WARNING - Current BW in: $(echo "scale=$SCALE; ($VALUEIN/$SDIVIN)"| bc)"$SLABELIN"bps Out: $(echo "scale=$SCALE; ($VALUEOUT/$SDIVOUT)"| bc)"$SLABELOUT"bps"
        exit $STATE_WARNING
    else
        echo -n "OK - Current BW in: $(echo "scale=$SCALE; ($VALUEIN/$SDIVIN)"| bc)"$SLABELIN"bps Out: $(echo "scale=$SCALE; ($VALUEOUT/$SDIVOUT)"| bc)"$SLABELOUT"bps"
        exit $STATE_OK
    fi
else
    echo "$FILE does not exist."
    exit $STATE_UNKNOWN
fi
exit $exitstatus
ssax
Dreams In Code
Re: check_rrdtraf measure Percentages
Post by ssax »
Great, thank you for posting your modifications, I'm sure others will find it useful!
