failure on E-importnagiosql
esv
Post by esv »
We're evaluating Nagios XI and I am trying to do a manual install of Nagios XI on a RHEL 6 x86_64 server, the install.log file indicates that the last script to be called was E-importnagiosql, here is the last message before the failure:
thanks,
IMPORTING /usr/local/nagios/etc/import/xiwzardtemplates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=admin&type=import&importsubmitted=true&chbOverwrite=1&subForm=Import&selImportFile[]=/usr/local/nagios/etc/import/xiwzardtemplates.cfg' -O nagiosql.import.monitoring
--2015-10-01 09:55:49-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.import.monitoring”
0K .......... .... 23.4K=0.6s
2015-10-01 09:55:50 (23.4 KB/s) - “nagiosql.import.monitoring” saved [14681]
root is not in the sudoers file. This incident will be reported.
RESETTING CONFIG PERMS FAILED!\n
hsmith
Agent Smith
Re: failure on E-importnagiosql
Post by hsmith »
What version of XI is this? What user are you logged in as?
Former Nagios Employee.
me.
esv
Post by esv »
Nagios XI Installation Log
DATE: Thu Oct 1 09:41:38 EDT 2015
DISTRO INFO:
RedHatEnterpriseServer
6.7
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=5R1.0
major=5
minor=R1.0
releasedate=2015-09-28
release=510
hsmith
Agent Smith
Post by hsmith »
Some questions:
1) What user are you logged in as when you are doing this install?
2) Have you made any modifications to the sudoers file?
3) Is your sudoers file managed by something such as puppet?
me.
esv
Post by esv »
1) User used: root
2) No modifications to the sudoers file as I can recall. - Do you need root have access to sudo, sounds redundant.
3) Sudoers file is not a managed file.
hsmith
Agent Smith
Post by hsmith »
Let's have a look at your sudoers file.
Here is mine for reference:
[root@hxi tmp]# cat /etc/sudoers
## Sudoers allows particular users to run various commands as
## the root user, without needing the root password.
## Examples are provided at the bottom of the file for collections
## of related commands, which can then be delegated out to particular
## users or groups.
## This file must be edited with the 'visudo' command.
## Host Aliases
## Groups of machines. You may prefer to use hostnames (perhaps using
## wildcards for entire domains) or IP addresses instead.
# Host_Alias     FILESERVERS = fs1, fs2
# Host_Alias     MAILSERVERS = smtp, smtp2
## User Aliases
## These aren't often necessary, as you can use regular groups
## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname
## rather than USERALIAS
# User_Alias ADMINS = jsmith, mikem
## Command Aliases
## These are groups of related commands...
## Networking
# Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclient, /usr/bin/net, /sbin/iptables, /usr/bin/rfcomm, /usr/bin/wvdial, /sbin/iwconfig, /sbin/mii-tool
## Installation and management of software
# Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
## Services
# Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig
## Updating the locate database
# Cmnd_Alias LOCATE = /usr/bin/updatedb
## Storage
# Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe, /bin/mount, /bin/umount
## Delegating permissions
# Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
## Processes
# Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
## Drivers
# Cmnd_Alias DRIVERS = /sbin/modprobe
# Defaults specification
# Disable "ssh hostname sudo <cmd>", because it will show the password in clear.
#         You have to run "ssh -t hostname sudo <cmd>".
#Defaults    requiretty
# Refuse to run if unable to disable echo on the tty. This setting should also be
# changed in order to be able to use sudo without a tty. See requiretty above.
Defaults   !visiblepw
# Preserving HOME has security implications since many programs
# use it when searching for configuration files. Note that HOME
# is already set when the the env_reset option is enabled, so
# this option is only effective for configurations where either
# env_reset is disabled or HOME is present in the env_keep list.
Defaults    always_set_home
Defaults    env_reset
Defaults    env_keep =  "COLORS DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS"
Defaults    env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults    env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
Defaults    env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults    env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY"
# Adding HOME to env_keep may enable a user to run unrestricted
# commands via sudo.
# Defaults   env_keep += "HOME"
Defaults    secure_path = /sbin:/bin:/usr/sbin:/usr/bin
## Next comes the main part: which users can run what software on
## which machines (the sudoers file can be shared between multiple
## systems).
## Syntax:
##      user    MACHINE=COMMANDS
## The COMMANDS section may have other options added to it.
## Allow root to run any commands anywhere
root    ALL=(ALL)       ALL
## Allows members of the 'sys' group to run networking, software,
## service management apps and more.
# %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LOCATE, DRIVERS
## Allows people in group wheel to run all commands
# %wheel        ALL=(ALL)       ALL
## Same thing without a password
# %wheel        ALL=(ALL)       NOPASSWD: ALL
## Allows members of the users group to mount and unmount the
## cdrom as root
# %users  ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
## Allows members of the users group to shutdown this system
# %users  localhost=/sbin/shutdown -h now
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
User_Alias      NAGIOSXI=nagios
User_Alias              NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
me.
esv
Post by esv »
I have the following 2 lines:
#%wheel ALL=(ALL) ALL
root ALL=(ALL) NOPASSWD: ALL
got a new failure:
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
ERROR: No files to import - exiting.  Were Nagios Core and NagiosQL installed?
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './E-importnagiosql'
here is the install.log file (short)
DATE: Thu Oct  1 14:08:40 EDT 2015
DISTRO INFO:
6.7
x86_64
THIS IS AN UPGRADE!
OLD VERSION:
full=5R1.0
major=5
minor=R1.0
release=510
INSTALLING:
full=5R1.0
major=5
minor=R1.0
release=510
Repos already configured - exiting.
Prereqs already installed - skipping...
Note: If you want to update the RPMs installed on this system, run your package manager's update command
Users/groups already configured - skipping.
Database servers already initialized - skipping.
/etc/services already updated - skipping.
sudoers already configured - skipping.
Firewall rules already configured - skipping.
Step completed OK
SELinux already configured - skipping.
Database backups already configured - skipping.
PHP limits already configured - skipping.
Sourceguardian already configured - skipping.
MRTG already configured - skipping.
Step completed OK
PHP timezone already configured - skipping.
Subcomponents already configured - skipping.
Nagios XI base files already installed - skipping.
Crontabs already configured - skipping.
Daemons already configured - skipping.
httpd: no process killed
Starting httpd: ^[[60G[^[[0;32m  OK  ^[[0;39m]^M
Sleeping...
hsmith
Agent Smith
Post by hsmith »
What is the output of a sudo -V command? I do not know if this was related, but there was some weird stuff going on with sudo awhile back.
me.
esv
Post by esv »
[root@xxxxxxxxxxx nagiosxi]# sudo -V
Sudo version 1.8.6p3
Configure options: --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu --target=x86_64-redhat-linux-gnu --program-prefix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/var/lib --mandir=/usr/share/man --infodir=/usr/share/info --prefix=/usr --sbindir=/usr/sbin --libdir=/usr/lib64 --docdir=/usr/share/doc/sudo-1.8.6p3 --with-logging=syslog --with-logfac=authpriv --with-pam --with-pam-login --with-editor=/bin/vi --with-env-editor --with-ignore-dot --with-tty-tickets --with-ldap --with-ldap-conf-file=/etc/sudo-ldap.conf --with-selinux --with-passprompt=[sudo] password for %p:  --with-linux-audit --with-sssd
Sudoers policy plugin version 1.8.6p3
Sudoers file grammar version 42
Sudoers path: /etc/sudoers
nsswitch path: /etc/nsswitch.conf
ldap.conf path: /etc/sudo-ldap.conf
ldap.secret path: /etc/ldap.secret
Authentication methods: 'pam'
Syslog facility if syslog is being used for logging: authpriv
Syslog priority to use when user authenticates successfully: notice
Syslog priority to use when user authenticates unsuccessfully: alert
Ignore '.' in $PATH
Send mail if the user is not in sudoers
Use a separate timestamp for each user/tty combo
Lecture user the first time they run sudo
Require users to authenticate by default
Root may run sudo
Allow some information gathering to give useful error messages
Visudo will honor the EDITOR environment variable
Set the LOGNAME and USER environment variables
Length at which to wrap log file lines (0 for no wrap): 80
Authentication timestamp timeout: 5.0 minutes
Password prompt timeout: 5.0 minutes
Number of tries to enter a password: 3
Umask to use or 0777 to use user's: 022
Path to mail program: /usr/sbin/sendmail
Flags for mail program: -t
Address to send mail to: root
Subject line for mail messages: *** SECURITY information for %h ***
Incorrect password message: Sorry, try again.
Path to authentication timestamp dir: /var/db/sudo
Default password prompt: [sudo] password for %p:
Default user to run commands as: root
Path to the editor for use by visudo: /bin/vi
When to require a password for 'list' pseudocommand: any
When to require a password for 'verify' pseudocommand: all
File descriptors >= 3 will be closed before executing a command
Reset the environment to a default set of variables
Environment variables to check for sanity:
	TZ
	TERM
	LINGUAS
	LC_*
	LANGUAGE
	LANG
	COLORTERM
Environment variables to remove:
	RUBYOPT
	RUBYLIB
	PYTHONUSERBASE
	PYTHONINSPECT
	PYTHONPATH
	PYTHONHOME
	TMPPREFIX
	ZDOTDIR
	READNULLCMD
	NULLCMD
	FPATH
	PERL5DB
	PERL5OPT
	PERL5LIB
	PERLLIB
	PERLIO_DEBUG
	JAVA_TOOL_OPTIONS
	SHELLOPTS
	GLOBIGNORE
	PS4
	BASH_ENV
	ENV
	TERMCAP
	TERMPATH
	TERMINFO_DIRS
	TERMINFO
	_RLD*
	LD_*
	PATH_LOCALE
	NLSPATH
	HOSTALIASES
	RES_OPTIONS
	LOCALDOMAIN
	CDPATH
	IFS
Environment variables to preserve:
	XAUTHORITY
	_XKB_CHARSET
	LINGUAS
	LANGUAGE
	LC_ALL
	LC_TIME
	LC_TELEPHONE
	LC_PAPER
	LC_NUMERIC
	LC_NAME
	LC_MONETARY
	LC_MESSAGES
	LC_MEASUREMENT
	LC_IDENTIFICATION
	LC_COLLATE
	LC_CTYPE
	LC_ADDRESS
	LANG
	USERNAME
	QTDIR
	PS2
	PS1
	MAIL
	LS_COLORS
	KDEDIR
	INPUTRC
	HISTSIZE
	HOSTNAME
	DISPLAY
	COLORS
Locale to use while parsing sudoers: C
Compress I/O logs using zlib
Directory in which to store input/output logs: /var/log/sudo-io
File in which to store the input/output log: %{seq}
Add an entry to the utmp/utmpx file when allocating a pty
Don't pre-resolve all group names
Local IP address and netmask pairs:
	XXXXXXXXXX/255.255.254.0
	XXXXXXXXXXXX/ffff:ffff:ffff:ffff::
Sudoers I/O plugin version 1.8.6p3
[root@XXXXXXXXX nagiosxi]#
hsmith
Agent Smith
Post by hsmith »
What directory are you trying to install from? AFAIK, the bugs were worked out of the script that made it error on running it from somewhere other than /tmp, but I could be wrong.
Is your system registered with RHN? If it's not, it may not be installing all of the packages it needs to be. Generally if this is the case the script detects that and errors out.
me.
