Anacron job 'cron.daily' logrotate
tylerhoadley
Post by tylerhoadley »
seems there is a small issue with /etc/logrotate.d/nagioslogserver. the 2015R2.2 release produces the following errors when the cron runs. Believe this was an issue with the version prior as well.
I receive all root email and this is output.
/etc/cron.daily/logrotate:
error: nagioslogserver:1 lines must begin with a keyword or a filename (possibly in double quotes)
error: nagioslogserver:2 unexpected text
error: nagioslogserver:3 unexpected text
error: nagioslogserver:4 unexpected text
error: nagioslogserver:5 unexpected text
error: nagioslogserver:6 unexpected text
error: nagioslogserver:7 unexpected text
error: nagioslogserver:8, unexpected text after {
error: nagioslogserver:8 lines must begin with a keyword or a filename (possibly in double quotes)
error: nagioslogserver:9 lines must begin with a keyword or a filename (possibly in double quotes)
error: nagioslogserver:10 lines must begin with a keyword or a filename (possibly in double quotes)
error: nagioslogserver:11 unexpected text
error: nagioslogserver:12 unexpected text
error: nagioslogserver:13 unexpected text
error: nagioslogserver:14 unexpected text
error: nagioslogserver:15 unexpected text
error: nagioslogserver:16 unexpected text
error: nagioslogserver:17, unexpected text after {
error: nagioslogserver:17 lines must begin with a keyword or a filename (possibly in double quotes)
Basically the file is in Windows line ending format instead of unix, there is ways to correct this, however this method below is the quickest way to resolve.
root@localhost:~/# file /etc/logrotate.dnagioslogserver
nagioslogserver: ASCII text, with CRLF line terminators
root@localhost:~/# yum install dos2unix -y
Loaded plugins: package_upload, product-id, security, subscription-manager
Setting up Install Process
Installed:
dos2unix.x86_64 0:3.1-37.el6
Complete!
root@localhost:~/# dos2unix /etc/logrotate.d/nagioslogserver
dos2unix: converting file nagioslogserver to UNIX format ...
root@localhost:~/# file /etc/logrotate.d/nagioslogserver
/etc/logrotate.d/nagioslogserver: ASCII text
Nagios Support, can you file this as a bug and have corrected in the next version so we don't have to keep correcting this after upgrades.
jolson
Attack Rabbit
Re: Anacron job 'cron.daily' logrotate
Post by jolson »
Thank you for the feedback - this bug fix will be included in our next release! May I close this thread?
Twits Blog
tylerhoadley
Yeah, Go ahead.
