We are moving our nagios server behind a firewall and will need to route a lot of our check_http over a proxy
I have added variables to /etc/sysconfig/nagios and have confirmed /etc/init.d/nagios is sources that file and have restarted.
However, none of my check make it through.
Is there a way to verify that it is actually sourcing that file?
Where else can I universally set proxy settings so I don't have to re-write all of my checks?
From the command line:
./check_http --hostname={HOSTNAME} -v
CRITICAL - Socket timeout after 10 seconds
./check_http --hostname={HOSTNAME} -L {PROXY} -v
**** CONTENT ****
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.4.7</center>
</body>
</html>
Thanks in advance
Check_http over a proxy
Re: Check_http over a proxy
What operating system are you running on? Did you update your profile to have the proxy added?
Former Nagios Employee.
me.
me.
redhat linux 6.something.
What profile? It is a shell environment setting already (etc/profile.d/{shell}.sh and .bash) and in /etc/sysconfig/nagios where the nagios documents say to put it.
Is there somewhere else my proxy settings should be so that nagios traffic naturally flows over it?
Is this the document you were referring to?
https://support.nagios.com/wiki/index.p ... th_Proxies
I was referring to ~/.bash_profile
me.
me.
FYI: that makes no difference because the same environment settings are pulled in from /etc/sysconfig/profile.d/{name}.sh or bash when the nagios user logs in.
Your reply only talks about nagiosXI...is there a similar nagios core 4.1.1 solution?
I'd like to know more about the configuration changes that you made to get your proxy working, and any guides you may have followed. What does your /etc/sysconfig/nagios files look like?
cat /etc/sysconfig/nagios
It is my understanding that Nagios Core is not aware of /etc/sysconfig/nagios, which is why I'm curious about any guides you might have followed. In my experience, re-writing your service checks is the only way to accomplish what you're trying to do, but if you have a guide or information that states otherwise I would like to see it.
amprantino
You may use the following to check a proxy without messing with the system
$WGET --proxy-user "domain\users" --proxy-password "mypassword" -t 1 --timeout=$TIMEOUT --proxy --execute=http_proxy=$HTTP_PROXY -O $PROXIED_FILE $SAMPLE_URL $LOG
Inside the script (line 73) you can define a user:define command{
command_name check_proxy_auth
command_line $USER1$/check_proxy $ARG1$ $ARG2$ $ARG3$
check_command check_proxy_auth!proxy1:8080!www.kernel.org!40
me.
me.
amprantino
To force traffic pass through a proxy add the following
export http_proxy=http://192.168.0.1:3128
Modify the above if you want to add username or password to access proxy.
