Here's the frame source (chrome). Nothing on the Page Source stood out and I'm one to many G&T's in to read through the frame source. If nothing stands out here let me know what else to look at. Again, no issues prior to the upgrade.
<h2>Acknowledge Problem <i class="fa fa-question-circle fa-14 pop" style="margin-left: 5px;" data-title="Acknowledge Problem" data-content="This command is used to acknowledge a host problem. When a host problem is acknowledged, future notifications about problems are temporarily disabled until the host changes from its current state. If you want acknowledgement to disable notifications until the host recovers, check the Sticky Acknowledgement checkbox. Contacts for this host will receive a notification about the acknowledgement, so they are aware that someone is working on the problem. Additionally, a comment will also be added to the host. Make sure to enter your name and fill in a brief description of what you are doing in the comment field. If you would like the host comment to remain once the acknowledgement is removed, check the Persistent Comment checkbox. If you do not want an acknowledgement notification sent out to the appropriate contacts, uncheck the Send Notification checkbox."></i></h2>
<input type="hidden" class="cmd-type" value="">
<table class="table table-condensed table-no-border table-auto-width">
<tr>
<td>Host Name <i class="fa fa-asterisk fa-req tt-bind" title="Required"></i></td>
<td><input type="text" class="form-control req" readonly value="iREALLYlikegraphs-CC"></td>
</tr>
<tr>
<td></td>
<td class="checkbox">
<label>
<input type="checkbox" id="sticky_ack" value="1" CHECKED> Sticky Acknowledgement </label>
<i class="fa fa-question-circle fa-14 pop" style="margin-left: 5px;" data-title="Sticky Acknowledgement" data-content="If you want acknowledgement to disable notifications until the host recovers, check the Sticky Acknowledgement checkbox."></i>
</td>
</tr>
<tr>
<td></td>
<label>
<input type="checkbox" id="send_notification" value="1" CHECKED> Send Notification </label>
<i class="fa fa-question-circle fa-14 pop" style="margin-left: 5px;" data-title="Send Notification" data-content="If you do not want an acknowledgement notification sent out to the appropriate contacts, uncheck the Send Notification checkbox."></i>
</td>
</tr>
<tr>
<td></td>
<label>
<input type="checkbox" id="persistent" value="1" > Persistent Comment </label>
<i class="fa fa-question-circle fa-14 pop" style="margin-left: 5px;" data-title="Persistent Comment" data-content="Make sure to enter your name and fill in a brief description of what you are doing in the comment field. If you would like the host comment to remain once the acknowledgement is removed, check the Persistent Comment checkbox."></i>
</td>
</tr>
<tr>
<td>Author <i class="fa fa-asterisk fa-req tt-bind" title="Required"></i></td>
<td><input type="text" class="form-control com_author req" readonly value="Friedrich Nietzsche"></td>
</tr>
<tr>
<td>Comment <i class="fa fa-asterisk fa-req tt-bind" title="Required"></i></td>
<td><input type="text" class="form-control com_data" style="width: 360px;" value="Problem has been acknowledged"></td>
</tr>
</table>
<button type="button" class="btn btn-sm btn-primary submit-add-ack">Submit</button>
<button type="button" class="btn btn-sm btn-default cancel">Cancel</button>
</div>
<div style="float: left;">
<div class="infotable_title">Quick Actions</div>
<table class="table table-condensed table-striped table-bordered table-no-margin">
<thead>
</thead>
<tbody>
<tr>
<td>
<!-- dynamic entries-->
<ul class="quickactions dynamic">
<div class="host_state_quick_actions" id="host_state_quick_actions_glicfb">
<li><a class="cmdlink" data-modal="add-ack" data-cmd-type="33"><img src="https://nagios.ilikegraphs.local/nagiosxi/images/ack_add.png">Acknowledge this problem</a></li><li><div class="commandimage"><a href="#" onClick='submit_command(16,{"host_name":"iREALLYlikegraphs-CC","cmd":25})'><img src="https://nagios.ilikegraphs.local/nagiosxi/images/nonotifications.png" alt="Disable notifications" title="Disable notifications"></a></div><div class="commandtext"><a href="#" onClick='submit_command(16,{"host_name":"iREALLYlikegraphs-CC","cmd":25})'>Disable notifications</a></div></li><li><div class="commandimage"><a href="#" onClick='submit_command(16,{"host_name":"iREALLYlikegraphs-CC","cmd":98,"start_time":1443992661})'><img src="https://nagios.ilikegraphs.local/nagiosxi/images/arrow_refresh.png" alt="Force an immediate check" title="Force an immediate check"></a></div><div class="commandtext"><a href="#" onClick='submit_command(16,{"host_name":"iREALLYlikegraphs-CC","cmd":98,"start_time":1443992661})'>Force an immediate check</a></div></li><li><div class="commandimage"><a href="#" onClick='window.open("https://nagios.ilikegraphs.local/nagiosxi/includes/components/pingaction/ping.php?host=23.31.183.193&cmd=go","pingaction","status=0,toolbar=0,height=300,width=600")'><img src="https://nagios.ilikegraphs.local/nagiosxi/includes/components/pingaction/images/ping.png" alt="Ping this host" title="Ping this host"></a></div><div class="commandtext"><a href="#" onClick='window.open("https://nagios.ilikegraphs.local/nagiosxi/includes/components/pingaction/ping.php?host=23.31.183.193&cmd=go","pingaction","status=0,toolbar=0,height=300,width=600")'>Ping this host</a></div></li><li><div class="commandimage"><a href="#" onclick="window.open('https://nagios.ilikegraphs.local/nagiosxi/includes/components/rdp/gordp.php?confirm=1&hostid=444&address=23.31.183.193','rdp','width=540,height=400,menubar=no,status=no,toolbar=no,scrollbars=no,resizable=yes');"><img src="https://nagios.ilikegraphs.local/nagiosxi/includes/components/rdp/images/rdp.png" alt="Connect to iREALLYlikegraphs-CC" title="Connect to iREALLYlikegraphs-CC"></a></div><div class="commandtext"><a href="#" onclick="window.open('https://nagios.ilikegraphs.local/nagiosxi/includes/components/rdp/gordp.php?confirm=1&hostid=444&address=23.31.183.193','rdp','width=540,height=400,menubar=no,status=no,toolbar=no,scrollbars=no,resizable=yes');">Connect to iREALLYlikegraphs-CC</a></div></li><li><div class="commandimage"><a href="#" onClick='window.open("https://nagios.ilikegraphs.local/nagiosxi/includes/components/tracerouteaction/traceroute.php?host=23.31.183.193&cmd=go","tracerouteaction","status=0,toolbar=0,height=300,width=700,scrollbars=yes")'><img src="https://nagios.ilikegraphs.local/nagiosxi/includes/components/tracerouteaction/images/traceroute.png" alt="Traceroute to this host" title="Traceroute to this host"></a></div><div class="commandtext"><a href="#" onClick='window.open("https://nagios.ilikegraphs.local/nagiosxi/includes/components/tracerouteaction/traceroute.php?host=23.31.183.193&cmd=go","tracerouteaction","status=0,toolbar=0,height=300,width=700,scrollbars=yes")'>Traceroute to this host</a></div></li>
</div><!--host_state_quick_actions-->
<script type="text/javascript">
$(document).ready(function(){
$("#host_state_quick_actions_glicfb").everyTime(10*1000, "timer-host_state_quick_actions_glicfb", function(i) {
var optsarr = {
"func": "get_host_status_quick_actions_html",
"args": {"hostname" : "iREALLYlikegraphs-CC", "host_id" : "444", "display" : "simple"}
var opts=array2json(optsarr);
get_ajax_data_innerHTML("getxicoreajax",opts,true,this);
</script>
</ul>
<!-- other entries-->
</td>
</tr>
</tbody>
</table>
</div>
<div class="clear"></div>
<div style="float: left; margin-top: 15px;"><!--comments-->
<div class="host_comments" id="host_comments_nk2f42">
<div class="infotable_title">Acknowledgements and Comments</div>No comments or acknowledgements.
</div><!--service_host-->
$("#host_comments_nk2f42").everyTime(10*1000, "timer-host_comments_nk2f42", function(i) {
var optsarr = {
"func": "get_host_comments_html",
</script>
</div>
<!--comments-->
