Hi all,
I just upgrade to the latest version 5R1.0. Everything goes ok, but when it finished, it continues saying that a new version of Nagios is still available. The system is updated and all features work fine with the new version. I attach a pic with the Updates section information.
Thanks a lot.
Nagios XI 5 upgrade problem (SOLVED)
Re: Nagios XI 5 upgrade problem (SOLVED)
SOLVED! Just clicked on: Check for updates now and the message dissapeared.
