Nagios Core 4.1.1 "Unable to get process data"
druid
Post by druid »
When going to my Nagios webpage I'm seeing a red 'X' and a message saying "Unable to get process data". Everything on else on the homepage looks fine, but when clicking on "Hosts" or "Services" links I get to a page saying: "Error: Could not read host and service status information!:
The Nagios log seems fine, however the httpd error_log states this error several times:
"AH01276: Cannot serve directory /var/www/html/: No matching DiretoryIndex (index.html, index.html.var, index.php, index.php) found, and server-generated directory index forbidden by Options directive"
Nothing is is /var/www/html/ and I'm not sure why Nagios is looking there. I'm not seeing anything pointing to it. Let me know if you'd like to see any config files.
Thank you!
eloyd
Cool Title Here
Re: Nagios Core 4.1.1 "Unable to get process data"
Post by eloyd »
How did you install Nagios? Is this a VM? Did you compile from source? Something else?
druid
Post by druid »
Installed Nagios from source. This is on a VM running CentOS 7.
eloyd
Cool Title Here
Post by eloyd »
Nagios should have installed a few files in /var/www/html. Take a look at your install log and see if you missed anything. If it were me, I'd start over with a fresh VM.
druid
Post by druid »
A previous employee had installed Nagios 3.5.1 on another VM. We are currently using this VM in production (planning on moving to new VM with Nagios v4). This old VM doesn't have anything in /var/www/html either
eloyd
Cool Title Here
Post by eloyd »
You should have something in your http configuration directory for nagios.conf that describes where to find Nagios. Check /etc/httpd/conf.d and see if there is a nagios.conf file there. If so, can you post its contents?
druid
Post by druid »
/etc/httpd/conf.d/nagios.conf
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
# This file contains examples of entries that need
# to be incorporated into your Apache web server
# configuration file.  Customize the paths, etc. as
# needed to fit your system.
#  SSLRequireSSL
   Options ExecCGI
   AllowOverride None
   <IfVersion >= 2.3>
      <RequireAll>
         Require all granted
#        Require host 127.0.0.1
         AuthName "Nagios Access"
         AuthType Basic
         AuthUserFile /usr/local/nagios/etc/htpasswd.users
         Require valid-user
      </RequireAll>
   </IfVersion>
   <IfVersion < 2.3>
      Order allow,deny
      Allow from all
#     Order deny,allow
#     Deny from all
#     Allow from 127.0.0.1
      AuthType Basic
      Require valid-user
   </IfVersion>
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
#  SSLRequireSSL
   Options None
   AllowOverride None
   <IfVersion >= 2.3>
      <RequireAll>
         Require all granted
         AuthType Basic
         Require valid-user
      </RequireAll>
   </IfVersion>
   <IfVersion < 2.3>
      Order allow,deny
      Allow from all
#     Order deny,allow
#     Deny from all
      AuthType Basic
      Require valid-user
   </IfVersion>
</Directory>
eloyd
Cool Title Here
Post by eloyd »
Have you tried: http://hostname/nagios as the URL?
druid
Post by druid »
I'm not quite sure what you mean.
hsmith
Agent Smith
Post by hsmith »
He's asking what URL you are using to attempt to access Nagios.
Former Nagios Employee.
me.
