New API question
BanditBBS
New API question
Post by BanditBBS »
Right now, for adding new hosts or services, is there any way to say "dont require fields" so I can supply a template so I don't get
    "error": "Missing required variables",
    "missing": [
        "max_check_attempts",
        "check_period",
        "notification_interval",
        "notification_period",
        "contacts OR contact_groups"
I really want to use the API for something I am doing, but I have to be able to use templates and not require those fields as they are all supplied by templates.
EDIT: I guess I could write the host cfg to the import folder, use the API to run the import, then write the services file and do the import again as a work around, but using the curl commands would be awesome!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
jomann
Development Lead
Re: New API question
Post by jomann »
That is actually a good point. I'll add something here for this because you can use the "use" attribute.
Edit: Added a parameter to pass called "force" so you can add &force=1 to skip the check.
BanditBBS
Post by BanditBBS »
jomann wrote:That is actually a good point. I'll add something here for this because you can use the "use" attribute.
Also for the services as well since we can use a template there please :)
You can close this thread.
jomann
Development Lead
Post by jomann »
It'll be in there for both of them this coming release (this week).
