<object-stream>
<map>
<entry>
<string>apollo.index.docNum.businessTotal</string>
<string>483907</string>
</entry>
<entry>
<string>apollo.index.docNum.trigger.businessTotal</string>
<string>3830</string>
</entry>
<entry>
<string>apollo.index.docNum.product.businessTotal</string>
<string>94073</string>
</entry>
<entry>
<string>apollo.index.diskSize</string>
<string>819.26</string>
</entry>
<entry>
<string>apollo.index.docNum.store.total</string>
<string>48</string>
</entry>
<entry>
<string>apollo.index.docNum.total</string>
<string>584400</string>
</entry>
<entry>
<string>apollo.index.docNum.upc.businessTotal</string>
<string>278698</string>
</entry>
<entry>
<string>apollo.index.docNum.store.businessTotal</string>
<string>48</string>
</entry>
<entry>
<string>apollo.index.docNum.price.businessTotal</string>
</entry>
<entry>
<string>
apollo.index.docNum.category_instruction.businessTotal
</string>
<string>4338</string>
</entry>
<entry>
<string>apollo.index.docNum.suggest.businessTotal</string>
<string>0</string>
</entry>
<entry>
<string>apollo.index.docNum.master.businessTotal</string>
<string>8847</string>
</entry>
</map>
</object-stream>
[root@esu4v187 libexec]# ./check_http -H macyds430 -p 8080 -u /apollo/info?section=INDEX -r "<string>apollo.index.docNum.product.businessTotal<string>|<string>apollo.index.docNum.trigger.businessTotal</string>|<string>apollo.index.docNum.upc.businessTotal</string>|<string>apollo.index.docNum.price.businessTotal</string>|<string>apollo.index.docNum.master.businessTotal</string>|<string>apollo.index.docNum.master.businessTotal</string>\n <string>0</string>"
HTTP OK: HTTP/1.1 200 OK - 2724 bytes in 1.184 second response time |time=1.184243s;;;0.000000 size=2724B;;;0
apollo.index.docNum.suggest.businessTotal = 0 but it's not catching it. How do get this to work? Can anyone help please.
