How to force a check in NNA
lucas.shelton
Whenever I modify an existing alert I have to wait for the 5 minutes cycle to complete before it runs a new check. Is there a way to force a check? I'm trying to tweak my alerting and it's a pain having to wait 5 minutes every time I make a change.
Re: How to force a check in NNA
There is not. Under the hood, NNA is collecting data and the cutoff period is hard-coded as every 5 minutes on-the-dot. While changing that value is technically possible, it would likely break things and be overwritten during the next update.
I can certainly put in a feature request for you. How would you describe your needs?
