Automate BPI servicegroups and hostsgroups syncs
tylerhoadley
Post by tylerhoadley »
I've been trying to automate the bpi hostsgroups and servicehosts syncs within the bpi module.
I believe this maybe possible via a webinject.pl script that I can run in Xi or via a /usr/bin/perl crontab entry. I'm not achieving the desired result although my script finishing without issue. So either I'm missing something during login or not passing proper args. Any help or knowledge as to what the index.php is expecting would be great
like I mentioned, this seems to complete all transaction correctly but it doesn't actually update the bpi group syncs. I used HTTP Live headers to capture the HTTP traffic commands, this is what I filtered out to try.
here is my attempt of using webinject..pl cases
<testcases repeat="1">
<case
	id="1"
	method="get"
	url="http://server.example.com/nagiosxi/login.php?redirect=/nagiosxi/admin/index.php%3f&noauth=1"
        verifyresponsecode="200"
        sleep="1"
<case
     	id="2"
	method="post"
        url="http://server.example.com/nagiosxi/login.php"
        postbody="nsp=cc483f1914b7e21c80f64054a69e4485&page=auth&debug=&pageopt=login&username=nagiosadmin&password=***********&loginButton=Login"
        posttype="application/x-www-form-urlencoded"
        verifypositive="Nagiosxi"
        sleep="1"
<case
     	id="3"
	method="get"
        url="http://server.example.com/nagiosxi/index.php"
        verifyresponsecode="302"
        sleep="1"
<case
     	id="4"
	method="get"
        url="http://server.example.com/nagiosxi/includes/components/nagiosbpi/index.php?cmd=syncservicegroups"
        sleep="5"
<case
     	id="5"
	method="get"in my last attempt, just in case
        url="http://server.example.com/nagiosxi/includes/components/nagiosbpi/index.php?cmd=synchostgroups"
        sleep="5"
</testcases>
I added sleep to help troubleshoot
Any help would be great.
ssax
Dreams In Code
Re: Automate BPI servicegroups and hostsgroups syncs
Post by ssax »
This may help you, I've taken it from a ticket I've worked on (the first part fixes a bug).
Edit this file:
/usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php
Find this code (around line 119):
function route_command($args)
    $cmd = grab_array_var($args, 'cmd', '');
Change it to:
    bpi_init();
Now when you sync your hostgroups/servicegroups it will update rather than replace keeping your existing settings.
You can add them to a new file under /etc/cron.d so that cron will run them ever 5 minutes (or whatever setting you want):
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=synchostgroups" > /usr/local/nagiosxi/var/bpi-hg.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncservicegroups" > /usr/local/nagiosxi/var/bpi-sg.log 2>&1
tylerhoadley
Awesome, works great.
however you have a " in both cmd calls (--cmd=synchostgroups" --cmd=syncservicegroups") that isn't needed
Prior to adding the cron, I ran the below to test the desired bpi output
# sudo -u nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=synchostgroups
CMD: synchostgroups
MSG: Backup successfully created.BPI configuration applied successfully!
# sudo -u nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncservicegroups
CMD: syncservicegroups
Then I appended this to the /etc/cron.d/nagiosxi cron file (I'll maintain this change as I upgrade version and nagiosxi file gets updated)
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=synchostgroups > /usr/local/nagiosxi/var/bpi-hg.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/html/includes/components/nagiosbpi/api_tool.php --cmd=syncservicegroups > /usr/local/nagiosxi/var/bpi-sg.log 2>&1
Cheers,
ssax
Dreams In Code
Post by ssax »
Woops, nice catch! :oops: Thanks for posting the solution.
