Starting ndo2db:Support for the specified database - FAILED
bala_bk
Post by bala_bk »
When i try to start ndo2db server i get the following error.
service ndo2db start
Starting ndo2db:Support for the specified database server is either not yet supported, or was not found on your system.
I tried changing
db_host = 127.0.0.1 and to localhost in ndo2db.cfg, but not successful.
Any pointers is very much appreciated :-)
Here is my system configuration.
# uname -a
Linux host-lnx194 3.0.13-0.27-default #1 SMP Wed Feb 15 13:33:49 UTC 2012 (d73692b) x86_64 x86_64 x86_64 GNU/Linux
cat /etc/SuSE-release
SUSE Linux Enterprise Server 11 (x86_64)
VERSION = 11
PATCHLEVEL = 2
# nagios -v
Nagios 3.0.6
Copyright (c) 1999-2008 Ethan Galstad (http://www.nagios.org)
Last Modified: 12-01-2008
License: GPL
mysql -u nagios -p nagios
Enter password:
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 10
Server version: 5.0.95 SUSE MySQL RPM
# grep db ndo*
ndo2db.cfg:lock_file=/usr/local/nagios/var/ndo2db.lock
ndo2db.cfg:ndo2db_user=nagios
ndo2db.cfg:ndo2db_group=nagios
ndo2db.cfg:db_servertype=mysql
ndo2db.cfg:db_host=localhost
ndo2db.cfg:db_port=3306
ndo2db.cfg:db_name=nagios
ndo2db.cfg:db_prefix=nagios_
ndo2db.cfg:db_user=nagios
ndo2db.cfg:db_pass=nagios
ndo2db.cfg:debug_file=/usr/local/nagios/var/ndo2db.debug
-Bala.
Re: Starting ndo2db:Support for the specified database - FAI
Could you post your full ndo2db.cfg file and the MYSQL config file (/etc/my.cnf)?
bala_bk
Post by bala_bk »
Attached are my config files for ndo and mysql.
# ps -aef|grep mysql
root 2821 1 0 Oct07 ? 00:00:00 /bin/sh /usr/bin/mysqld_safe --mysqld=mysqld --user=mysql --pid-file=/var/lib/mysql/mysqld.pid --socket=/var/lib/mysql/mysql.sock --datadir=/var/lib/mysql
mysql 2861 2821 0 Oct07 ? 00:00:20 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/lib/mysql/mysqld.pid --skip-external-locking --port=3306 --socket=/var/lib/mysql/mysql.sock
root 5472 5387 0 10:10 pts/0 00:00:00 grep mysql
ndo2db.cfg
(573 Bytes) Downloaded 374 times
bala_bk
Post by bala_bk »
Attached mysql and ndo2db config files.
PS:Renamed my.cnf to my.cnf.cfg for uploading the attachement.
ndo2db.cfg
(573 Bytes) Downloaded 346 times
my.cnf.cfg
mysql confi file
(6.15 KiB) Downloaded 366 times
Can you run the following to see if the nagios database exists?
echo "show databases;" | mysql -u nagios -pnagios
You may need to use the root account to get this to work for you.
bala_bk
Post by bala_bk »
Hi
Yes the database is available and also the tables with prefix "nagios_*"
# echo "show databases;"|mysql -u nagios -pnagios
Database
information_schema
nagios
test
# echo "use nagios;show tables"|mysql -u nagios -pnagios
Tables_in_nagios
nagios_acknowledgements
nagios_commands
nagios_commenthistory
nagios_comments
nagios_configfiles
nagios_configfilevariables
nagios_conninfo
nagios_contact_addresses
nagios_contact_notificationcommands
nagios_contactgroup_members
Is that the full list of tables from the show tables output?
If that is the full output, you are missing a lot of tables and you should rerun through the install and recreate the database.
bala_bk
Post by bala_bk »
No, its just a snapshot of list of tables. Complete list is as below. Also attached my config.log
Tables_in_nagios
nagios_commands
nagios_comments
nagios_configfiles
nagios_conninfo
nagios_contactgroups
nagios_contactnotificationmethods
nagios_contactnotifications
nagios_contacts
nagios_contactstatus
nagios_customvariables
nagios_customvariablestatus
nagios_dbversion
nagios_downtimehistory
nagios_eventhandlers
nagios_externalcommands
nagios_flappinghistory
nagios_host_contactgroups
nagios_host_contacts
nagios_host_parenthosts
nagios_hostchecks
nagios_hostdependencies
nagios_hostescalation_contactgroups
nagios_hostescalation_contacts
nagios_hostescalations
nagios_hostgroup_members
nagios_hostgroups
nagios_hosts
nagios_hoststatus
nagios_instances
nagios_logentries
nagios_notifications
nagios_objects
nagios_processevents
nagios_programstatus
nagios_runtimevariables
nagios_scheduleddowntime
nagios_service_contactgroups
nagios_service_contacts
nagios_service_parentservices
nagios_servicechecks
nagios_servicedependencies
nagios_serviceescalation_contactgroups
nagios_serviceescalation_contacts
nagios_serviceescalations
nagios_servicegroup_members
nagios_servicegroups
nagios_services
nagios_servicestatus
nagios_statehistory
nagios_systemcommands
nagios_timedeventqueue
nagios_timedevents
nagios_timeperiod_timeranges
nagios_timeperiods
# gcc --version
gcc (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973]
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
config.log
(57.87 KiB) Downloaded 365 times
jdalrymple
Skynet Drone
Post by jdalrymple »
I don't see a couple of key components:
grep module /usr/local/nagios/etc/nagios.cfg
grep -v ^$ /usr/local/nagios/etc/ndomod.cfg | grep -v "^#"
If my paths aren't right for your environment, please adjust to suit.
bala_bk
Post by bala_bk »
hi,
# grep module /etc/nagios/nagios.cfg
# This directive is used to specify an event broker module that should
# to load more than one module. Arguments that should be passed to
# the module at startup are seperated from the module path by a space.
# Do NOT overwrite modules while they are being used by Nagios or Nagios
# The correct/safe way of updating a module is by using one of these methods:
# 1. Shutdown Nagios, replace the module file, restart Nagios
# 2. Delete the original module file, move the new module file into place, restart Nagios
# broker_module=<modulepath> [moduleargs]
#broker_module=/somewhere/module1.o
#broker_module=/somewhere/module2.o arg1 arg2=3 debug=0
broker_module=/usr/local/nagios/bin/ndomod.o config_file="/etc/nagios/ndomod.cfg"
# locate ndomod.cfg
# grep -v ^$ /etc/nagios/ndomod.cfg|grep -v "^#"
instance_name=default
output_type=unixsocket
output=/usr/local/nagios/var/ndo.sock
tcp_port=5668
use_ssl=0
output_buffer_items=5000
buffer_file=/usr/local/nagios/var/ndomod.tmp
file_rotation_interval=14400
file_rotation_timeout=60
reconnect_interval=15
reconnect_warning_interval=15
data_processing_options=-1
config_output_options=2
acknowledgement_data=1
adaptive_contact_data=1
adaptive_host_data=1
adaptive_program_data=1
adaptive_service_data=1
aggregated_status_data=1
comment_data=1
contact_status_data=1
downtime_data=1
event_handler_data=1
external_command_data=1
flapping_data=1
host_check_data=1
host_status_data=1
log_data=1
main_config_data=1
notification_data=1
object_config_data=1
process_data=1
program_status_data=1
retention_data=1
service_check_data=1
service_status_data=1
statechange_data=1
system_command_data=1
timed_event_data=1
