JSON and JSON_LINES delimiter
fabian.vanderhoeven
I've build my own log forwarder using python (using inotify). The reason beinig the logstash-forwarder is to heavy for our systems (accessing directory listings a lot). The way our application write logs is very inefficient (logswitch ones or twice a minute) and logstash-forwarder can't cope with that.
Anyway, the issue i've come accross is as follows. My logforwarder worked fine using UDP and JSON input filter, but when I switched to TCP (because we wanted to use multiline), it didn't work anymore (yes, i've allready decreased the workers).
When I used the shipper.py script provided with Nagios logserver, the logs DID get pushed to elasticsearch. I compared the messages my logforwarder made and the ones the shipper.py made, and they were identical.
I tried 2 days of trying it to get to work (a lot of frustration)
Finally is used tcpdump to analyse the payload and found that the message sent with shipper.py had a linefeed (\n, "0A") at the end of the message. My logforwarder didn't have it (the payload was 1 byte shorter).
Last line from shipper.py:
0x0280: 2241 7070 6c2d 4841 524d 227d 0a "Appl-HARM"}.
Last line from my logforwarder:
0x0280: 2241 7070 6c2d 4841 524d 227d "Appl-HARM"}
I think this is a bug because according to the documentation from elasticsearch's logstash (https://www.elastic.co/guide/en/logstas ... -json.html) the JSON input doesn't need a \n as a delimiter. If you want to use a \n as a delimiter, you should use JSON_LINES. But apparently the JSON input also needs \n as a delimiter. I don't know if this bug is know or allready fixed in the newer 1.5.3 logstash, but it is worth mentioning.
Re: JSON and JSON_LINES delimiter
Thank you for the bug report. In addition to the packet difference you've noted, are you certain that the TCP transactions are the same?
The multiline codec/filter expects that your logs are all transferred as a single TCP stream - meaning that a single four-way handshake takes place and the rest of the log data is transferred within that session.
It's possible that your custom application is opening a new TCP stream (new four-way handshake) for every line that it sends to Nagios Log Server, which would stop the multiline filter from functioning properly. You can verify this with a TCPdump as you had before - is there a different in handshakes between shipper.py and your custom shipper, or is the only different the missing byte?
Let me know, thanks!
Best,
Jesse
Best,
Jesse
fabian.vanderhoeven
Hi Jesse,
This test I ran was only whit 1 logline (I used just 1 line for easy testing purposes). The multiline tests are next. But my logshipper does send multiple lines in just 1 stream.
I just mentioned the multiline part because that was the reason we jumper from UDP to TCP.
Regards,
Fabian.
Regards,
Fabian.
Would you please provide me with an example input and an example filter so that I may reproduce your results in a test environment? After reproduction, I am happy to submit a bug report to our developers. Thank you!
fabian.vanderhoeven
This is the input i'm using:
tcp {
type => 'import_json'
tags => 'import_json'
port => 2057
codec => json
I have no filters defined in my dev environment.
This is a small python script which demonstrates the issue:
The first send line doesn't work, the second send line does work.
tcp {
port => 2057
codec => json
#!/usr/bin/python
import socket
try:
import json
except ImportError:
import simplejson as json
logserver_ip = '192.168.5.100'
logserver_port = 2057
json_message = {}
json_message['message'] = 'test'
json_message['sourcetype'] = 'Appl-Test'
json_message['logfile'] = '/tmp/test.log'
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((logserver_ip, logserver_port))
#s.send(json.dumps(json_message))
s.send((json.dumps(json_message) + '\n'))
s.close()
Yup - the script and input that you've given me show that this is a bug, plain as day. I've submitted an issue to the Logstash team: https://github.com/logstash-plugins/log ... /issues/15
Let's follow it over there and check on the response. If we come up with a solution in-house, we'll submit a pull request to the Logstash team. Thanks!
Jesse
Jesse
What about forwarding JSON log files from a linux host, using rsyslogd.
Found a post from 2012: http://untergeek.com/2012/10/11/using-r ... -logstash/ that discusses rsyslogd with JSON over to Logstash.
However, when I do this, it's only sending individual lines of my test log:
Here's my supplemental rsyslogd conf:
LogServer results:
"id": 1,
"gender": "Female",
"first_name": "Rachel",
"last_name": "Porter",
"email": "[email protected]",
"ip_address": "243.123.228.116"
"id": 2,
"gender": "Male",
"first_name": "Fred",
"last_name": "Dunn",
"ip_address": "106.47.41.159"
"id": 3,
"gender": "Female",
"first_name": "Brenda",
"last_name": "Alvarez",
"ip_address": "134.95.107.229"
}Code: Select all
cat 90-nagioslogserver_var_log_ssoAudit.log.conf
$ModLoad imfile
$InputFilePollInterval 10
$PrivDropToGroup adm
$WorkDirectory /var/lib/rsyslog
# Input for ssoAudit
$InputFileName /var/log/ssoAudit.log
$InputFileTag ssoAudit:
$InputFileStateFile nls-state-var_log_ssoAudit.log # Must be unique for each file being polled
# Uncomment the folowing line to override the default severity for messages
# from this file.
#$InputFileSeverity info
$InputFilePersistStateInterval 20000
$InputRunFileMonitor
$template ls_json,"{%timestamp:::date-rfc3339,jsonf:@timestamp%,%source:::jsonf:@source_host%,\"@source\":\"syslog://%fromhost-ip:::json%\",\"@message\":\"%timestamp% %app-name%:%msg:::json%\",\"@fields\":{%syslogfacility-text:::jsonf:facility%,%syslogseverity-text:::jsonf:severity%,%app-name:::jsonf:program%,%procid:::jsonf:processid%}}"
# Forward to Nagios Log Server and then discard, otherwise these messages
# will end up in the syslog file (/var/log/messages) unless there are other
# overriding rules.
if $programname == 'ssoAudit' then @@brnagiosls1.ux.corp.local:2057;ls_json
if $programname == 'ssoAudit' then ~
"_index": "logstash-2016.04.08",
"_type": "import_json",
"_id": "AVP3cA5MGlbcNFEpbl_z",
"_score": null,
"_source": {
"@timestamp": "2016-04-08T19:53:46.208Z",
"@source_host": "brnagios1",
"@source": "syslog://",
"@message": "Apr 8 15:53:46 ssoAudit: \"gender\": \"Female\",",
"@fields": {
"facility": "local0",
"severity": "notice",
"program": "ssoAudit",
"processid": "-"
"@version": "1",
"host": "10.10.25.39",
"type": "import_json",
"tags": [
"import_json",
"_grokparsefailure"
"syslog_severity_code": 5,
"syslog_facility_code": 1,
"syslog_facility": "user-level",
"syslog_severity": "notice"
"sort": [
1460145226208,
1460145226208
}Andrew J. - Do you even grok?
Are all of the lines showing up in your server, just one at a time? Or are you missing lines completely?
Former Nagios Employee.
me.
me.
We were getting single lines.
The unix admin has since updated the supplement config file as:
We're now getting every thing as one message, but it's JSON inside SYSLOG:
$ModLoad imfile
$PrivDropToGroup sys
$InputFileName /apps/forgerock/openam-config/auth/debug/ssoAudit.log
$InputFileStateFile ssoAudit.log # Must be unique for each file being polled
# from this file.
#$InputFilePersistStateInterval 20000
$InputFileSeverity error
$InputFileFacility local7
# overriding rules.
if $programname == 'ssoAudit' then stop
<187>Apr 8 13:24:19 slfroamd1 ssoAudit: {"employeeId":"couldn\u0027t retireve the emplID, persistntID is ","companyId":"couldn\u0027t retireve the companyID for persistantID \u003d ","timeStamp":"2016/04/07 13:11:48 Pacific Daylight Time","userIP":"10.30.27.85","environment":"ssodev.t.com","serverIP":"10.30.27.131","application":"SSO","feature":"CLIENT INTIATED SSO","resource":"smoketest","method":"POST","statusCode":200,"userAgentInfo":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_3) AppleWebKit/601.4.4 (KHTML, like Gecko) Version/9.0.3 Safari/601.4.4"}Andrew J. - Do you even grok?
Found this as well http://www.rsyslog.com/coupling-with-lo ... #more-2356 but NLS doesn't use redis.
