I had a passive check in ncpa.cfg that was:
%HOSTNAME%|root free = /disk/logical/|/used_percent --warning 90 --critical 95
but I changed the name of it to:
%HOSTNAME%|disk_root_used = /disk/logical/|/used_percent --warning 90 --critical 95
Saved/Restarted the ncpa_passive service. However, the root free passive check keeps showing up in unconfigured objects?? Was there something else I need to do ?
Thanks!
ncpa.cfg
Re: ncpa.cfg
I'm going to close this since you have a duplicate open here: https://support.nagios.com/forum/viewto ... 184#156489
Please only open one topic per issue, so we can focus our efforts in one location.
