Need to convert String data type to Integer for graphing
Nagman333
Post by Nagman333 »
I have several network management parameters that I would like to monitor via SNMP. I am able to monitor these parameters okay without any issue and I see the results in Nagios.
The issue is that I would like to graph the results for historical analysis but the data types are of type: String. It appears that Nagios is only able to graph Integer/numeric data types. Not sure if that is 100% correct though?
Is there any way to accomplish this?
Mark
Re: Need to convert String data type to Integer for graphing
From what I found, you cannot get performance data if the output is a string.
You would have to write a wrapper script to convert it.
Can you show how the command is run and the output you are receiving?
