Not able to start NSclient++ service on the Host.
RIDS_I2MP
Post by RIDS_I2MP »
I am not able to start the NSclient++(32bit) service on the host, it is displaying an error message as "Could not start NSClient++ (32bit) service on the local computer".
I am attaching the details of the host and the error message received.
kindly let me know the solution of the issue.
Thanks & Regards,
I2MP Team.
hsmith
Agent Smith
Re: Not able to start NSclient++ service on the Host.
Post by hsmith »
What version are you trying to install? I've seen reports that version 0.4.101 works on Windows Server 2003.
Former Nagios Employee.
me.
RIDS_I2MP
Post by RIDS_I2MP »
The NS client ++ version is 0.3.9.327, please find the snapshot for version and more details.
The client was working fine it has stopped unexpectedly.
Thanks & Regards,
I2MP Team.
It looks like you're running 32 bit NSClient with a 64 bit OS. Try reinstalling the 64 bit version of NS Client (still 0.3.9) and that may fix it for you.
RIDS_I2MP
Post by RIDS_I2MP »
I have confirmed the OS and NS client ++ both are 32 bit.
Thanks & Regards,
I2MP Team.
hsmith
Agent Smith
Post by hsmith »
Can you please try to use NSClient version 0.4.101 and let us know what happens?
me.
Ah, didn't realize that enterprise version supported 16GB of ram. Prior to upgrading, can you confirm the two items below.
Navigate to start -> type 'services.msc' -> look for NSClient++ -> right click it, and select properties. What is the Path to executable?
Also, check C:\Program Files\NSClient++\nsclient.log and see if anything is generated in there. If so, please post the last 20 lines.
RIDS_I2MP
Post by RIDS_I2MP »
Kindly find the attached NSClient++ properties and NSClient log file data.
The executable file path is C:\Program Files\NSclient++\nsclient++.exe.
Thanks & Regards,
I2MP Team.
jdalrymple
Skynet Drone
Post by jdalrymple »
I can't be sure, but my googling leads me here:
http://blogs.technet.com/b/askperf/arch ... r-not.aspx
Can you follow the steps in that blog entry to verify that your WMI repository is not corrupt?
This might be equally handy:
https://technet.microsoft.com/en-us/lib ... 04265.aspx
