Having issues install the agent on some of our 5.10 solaris boxes:
Do you want to continue with the installation of <SMCtop> [y,n,?] Using </usr/local> as the package base directory.
## Processing package information.
## Processing system information.
4 package pathnames are already properly installed.
## Verifying disk space requirements.
## Checking for conflicts with packages already installed.
The following files are already installed on the system and are being
used by another package:
/usr/local/bin <attribute change only>
/usr/local/man <attribute change only>
/usr/local/man/man1 <attribute change only>
Do you want to install these conflicting files [y,n,?,q] ## Checking for setuid/setgid programs.
Installing top as <SMCtop>
## Installing part 1 of 1.
pkgadd: ERROR: unable to create package object </usr/local/bin>.
unable to fix attributes
pkgadd: ERROR: unable to create package object </usr/local/bin/sparcv7>.
pathname does not exist
unable to create directory
/usr/local/bin/sparcv7/top
ERROR: attribute verification of </usr/local/bin/sparcv7/top> failed
pkgadd: ERROR: unable to create package object </usr/local/bin/sparcv9>.
/usr/local/bin/sparcv9/top
ERROR: attribute verification of </usr/local/bin/sparcv9/top> failed
/usr/local/bin/top
ERROR: attribute verification of </usr/local/bin/top> failed
pkgadd: ERROR: unable to create package object </usr/local/doc>.
pkgadd: ERROR: unable to create package object </usr/local/doc/top>.
/usr/local/doc/top/Changes
ERROR: attribute verification of </usr/local/doc/top/Changes> failed
/usr/local/doc/top/FAQ
ERROR: attribute verification of </usr/local/doc/top/FAQ> failed
/usr/local/doc/top/INSTALL
ERROR: attribute verification of </usr/local/doc/top/INSTALL> failed
/usr/local/doc/top/LICENSE
ERROR: attribute verification of </usr/local/doc/top/LICENSE> failed
/usr/local/doc/top/README
ERROR: attribute verification of </usr/local/doc/top/README> failed
/usr/local/doc/top/Y2K
ERROR: attribute verification of </usr/local/doc/top/Y2K> failed
pkgadd: ERROR: unable to create package object </usr/local/man>.
pkgadd: ERROR: unable to create package object </usr/local/man/man1>.
/usr/local/man/man1/top.1
ERROR: attribute verification of </usr/local/man/man1/top.1> failed
[ verifying class <none> ]
ERROR: attribute verification of </usr/local/bin> failed
ERROR: attribute verification of </usr/local/man> failed
ERROR: attribute verification of </usr/local/man/man1> failed
Installation of <SMCtop> partially failed.SunOS appzone06-dev 5.10 Generic_141444-09 sun4v sparc SUNW,Sun-Fire-T200
I'm installing the agent from this document:
https://assets.nagios.com/downloads/nag ... _Agent.pdf
Any ideas on what I can try?
