Format error in e-mail notification
rclav
Post by rclav »
I'm running NSCLient++ 0.4.3.143 on a Windows Server 2008 operating system (let's call it HOST1). Every time I receive an e-mail notification about that particular server, the date format in the Additional Info field seems to be wrongly parsed. Furthermore, an unexpected (%count%) word appears somewhere within the message.
This only happens in notifications of that particular server. I have another Windows Server 2008 host (HOST2) being monitored by the same Nagios instance, and notifications from that server seem to be OK. I think it may be related to the NSClient++ version I'm using on HOST1 (the second server is running a slightly older version).
What could be happening? Is there a way to solve this problem without installing an older version of NSClient++?
Example:
***** Nagios *****
Notification Type: PROBLEM
Service: Log <ServerName>
Host: <ServerName>
Address: <ServerIP>
State: WARNING
Date/Time: Fri Oct 16 15:49:12 CLT 2015
Additional Info:
error: 2w 2d 17:23, Microsoft-Windows-TerminalServices-RemoteConnectionManager: Autoreconnect failed to reconnect user to session because authentication failed. (Access is denied. ) (%count%)
Best regards,
rclav
Re: Format error in e-mail notification
To get some clarification, what is wrong with the date? CLT appears to be Chile Standard Time: http://www.timeanddate.com/time/zones/clt
And for the %count% variable (not macro, big difference), how are you referencing that in your notification command?
Post by Box293 »
I believe the count business is related to NSClient++.
Is this an active check or a passive check?
When the service is in this state, can you please send a screenshot of the service so we can see the output.
Also, can you provide any information that is logged in /usr/local/nagios/var/nagios.log in relation to this service.
rclav
Post by rclav »
Thanks for your answers.
tmcdonald wrote:To get some clarification, what is wrong with the date? CLT appears to be Chile Standard Time: http://www.timeanddate.com/time/zones/clt
The line that is displaying a wrongly formatted date is error: 2w 2d 17:23 in the Additional Info field. This doesn't happen when I receive a notification from the other host (which is being monitored by the same nagios daemon, running in another server [a third one]). Where can I see the notification commands? (I didn't configure the nagios monitor myself, just installed and configured NSClient++ in one of the hosts).
Box293 wrote:I believe the count business is related to NSClient++.
The notification I've mentioned corresponds to a passive check. I've looked at the log files and they only provide information about the active checks. I think my problem is related to the NSClient++ version I'm using.
Thanks for any help you can provide.
The Notification commands are defined in the commands.cfg file and if Nagios was installed to the default folders, it can be found here.
/usr/local/nagios/etc/commands.cfg
If you want to log passive checks, you can edit the nagios.cfg file and change the following from
log_passive_checks=0
to
log_passive_checks=1
Save it out and restart the nagios process. That may help you in debugging this issue.
