Nagios Configuration Help Please
kwhogster
Post by kwhogster »
Raspbery Pi Raspbian Jesse
Apache2 running
Windows 10 Ie or Edge
Nagios 4.0.8
When I browse the Nagios Main Page I see Nagios Core big display and under it is displays RED X NOT RUNNNIG
That is issue One
Issue two
in Nagios.cfg file I changed this line
#cfg_file=/usr/local/Nagios/etc/objects/windows.cfg
to
Removed the #
did a service Nagios reload
root@raspberrypi:/usr/local/nagios/etc# service nagios reload
Running configuration check...
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Error: Unexpected token or statement in file '/usr/local/nagios/etc/objects/windows.cfg' on line 65.
If I put the # back
[ ok ] Starting nagios (via systemctl): nagios.service.
Then Nagios starts
root@raspberrypi:/usr/local/nagios/etc# service nagios status
● nagios.service - Nagios
Loaded: loaded (/etc/systemd/system/nagios.service; enabled)
Active: active (running) since Sat 2015-10-17 14:04:12 UTC; 11min ago
Main PID: 935 (nagios)
CGroup: /system.slice/nagios.service
├─935 /usr/local/nagios/bin/nagios /usr/local/nagios/etc/nagios.cfg
├─936 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─937 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─938 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─939 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
└─940 /usr/local/nagios/bin/nagios /usr/local/nagios/etc/nagios.cfg
Oct 17 14:04:13 raspberrypi nagios[935]: wproc: Registry request: name=Core Worker 937;pid=937
Oct 17 14:04:13 raspberrypi nagios[935]: wproc: Registry request: name=Core Worker 938;pid=938
Oct 17 14:04:13 raspberrypi nagios[935]: wproc: Registry request: name=Core Worker 939;pid=939
Oct 17 14:04:13 raspberrypi nagios[935]: wproc: Registry request: name=Core Worker 936;pid=936
Oct 17 14:04:13 raspberrypi nagios[935]: Successfully launched command file worker with pid 940
Oct 17 14:15:18 raspberrypi systemd[1]: Started Nagios.
But the Nagios Core Home Page still shows RED X NOT RUNNING
Issue Three
Other problem with my browsers from the Main Home Page not matter which menu Item I choose example under current status I select HOSTS the display is all unreadable characters
So
1. Nagios Home Page shows RED X NOT RUNNING
2. Removing # from Nagios.cfg file causes Nagios to fail to start
3. Nagios Home page bad output when displaying any element
Any help would be appreciated.
kwhogster
Re: Nagios Configuration Help Please
Post by kwhogster »
Update
Just upgraded to Nagios 4.1.1 Plugins 2.1.1
Same results as above.
Need help
New Note
I am now able to update the Nagios.cfg I was able to remove the # and now the reload works.
just can not browse the page Thoughts
eloyd
Cool Title Here
Post by eloyd »
The plugins do not have anything to do with Nagios Core itself.
This error leaps out at me and I'm not sure I see anything that addresses it:
Can you post that file?
Usually we see that with copy+paste mixups in the configs, from an open "define" line or mismatched curly brace.
kwhogster
Post by kwhogster »
I got it working now
Was not Nagios it was Apache2
To get rid of the Red X Not running message and the CGI pages not working to work
Had to run this
sudo a2enmod cgi
sudo service apache2 restart
hsmith
Agent Smith
Post by hsmith »
Thank you for sharing the fix with us! Is there anything else we can do for you, or is this one all right to lock up?
Former Nagios Employee.
me.
kwhogster
Post by kwhogster »
Yes all good problem solved
