Check_nrpe for Windows Host
SJ04
Post by SJ04 »
Hi Guys,
I am bit Lost with
 Check_nrpe
configuration for Monitoring the Windows Remote Host. i have installed the Nagios on the Ubuntu 14.04 server and wants to monitor the Windows Server.(both machine are in the same subnet).
i have installed the NSclient++ on the windows host and i am successfully able to monitor with Check_nt but can't monitor the Host via Check_nrpe , i am having this error
No output Returned from plugin
can someone please help me with this.
thanks
hsmith
Agent Smith
Re: Check_nrpe for Windows Host
Post by hsmith »
What version of Windows, what version of NSClient?
Can you post a copy of your nsc/nsclient.ini file with any passwords/public IPs obfuscated?
Former Nagios Employee.
me.
Post by Box293 »
I have an NSClient++ NRPE guide here:
http://sites.box293.com/nagios/guides/n ... dows/0-4-x
Specifically the command line steps should make it work.
If not you can create the ini file from scratch:
http://sites.box293.com/nagios/guides/n ... t-ini-file
SJ04
Post by SJ04 »
Box293 wrote:I have an NSClient++ NRPE guide here:
Hi @Box293
Thanks a lot for Sharing this Documentation about Nagios. this Really Helped me a lot, I actually Never found such a brief and good info about Nagios Before your Link :)
hsmith
Agent Smith
Post by hsmith »
His website helped me a lot when I started as well. Is there anything else we can do for you in this thread?
me.
SJ04
Post by SJ04 »
hsmith wrote:His website helped me a lot when I started as well. Is there anything else we can do for you in this thread?
@hsmith ,You guys have helped me for this Problem but i have few other question but i think i need to create another Thread for it.
thanks for the Help and we can close this Thread .
