Hi we just purchased pro and it came with Core 3.2.3 followed the instructions to uprgade no errors and it I'm still at 3.2.3 here are the instructions
Upgrade VM
To upgrade your VM to the latest version, run the following from the console as root
cd /tmp
rm -rf corevm* nagioscore*
wget [removed link]
tar xzf corevm-latest.tar.gz
cd /tmp/nagioscore
./upgrade
If anyone has any help that would be great.. I searched but couldn't come up with anything. Thanks
Upgrade
Re: Upgrade
When you ran the upgrade, did you receive any errors?
If so, can you post them here?
