It seems I'm suffering from an old issue that re-appeared. I'm unable to make one of the dashlets on my home dashboard float again.
https://support.nagios.com/forum/viewto ... t=+dashlet
This means I can't move this dashlet, what's pretty annoying. I tried my previous solution (scrolling), but that didn't work. As it's my home dashboard I also can't delete it.
Any suggestions to solve this? I tried on different browsers, different resolutions, different zooming, fullscreen.
Grtz
Willem
Nagios XI 5 - Dashlet issue
Nagios XI 5.8.1
https://outsideit.net
Re: Nagios XI 5 - Dashlet issue
If you try in firefox/chrome and open up the developer console (F12) do you see any javascript errors pop up after you try to move it?
Sean,
The problem is that it's not possible to move it, because it is pinned. I tried moving it anyway for you, but I don't see any messages appearing in the developer console.
Grtz
Grtz
Nagios XI 5.8.1
Ok,
I managed to solve this, thanks to my colleague Michiel. When going to the developer console, click Select item, click the problem dashlet. Then go a few divs higher so you are sure you have selected the entire dashlet. Go to the elements.style and edit the top css element. My problems dashlets was at '-51' and I changed it to '+55' after which I was able to unpin the dashlets and move it to it's correct place.
This thread can be closed.
Nagios XI 5.8.1
