Exchange DB monitoring
bsivavani
Post by bsivavani »
Hello All,
I have urgent requirement to monitor Exchange Database (TESTDB) disk space and it is under Disk3 partition. Currently installed NSClient++ in Exchange server. We have Nagios Xi installed in another server. Can you let me know what are configuration files that I need to modify.
Please suggest possible solution.
Re: Exchange DB monitoring
I searched through the exchange and found this plugin - https://exchange.nagios.org/directory/P ... ck/details
Although it's not an official Nagios plugin, this might work for your needs.
bsivavani
Post by bsivavani »
Thanks. Can you give us official plugin as this is impacting production.
Also send us steps for plugin install.
We do not have an official plugin for checking the size of an exchange database. We do our best to support the plugins in exchange, but cannot guarantee them.
bsivavani
Post by bsivavani »
Please suggest steps to install plugin and configuration files which I have to modify. Thanks
Take a look at https://assets.nagios.com/downloads/nag ... ios-XI.pdf for how to install a plugin.
As for the plugin itself, you will need to open it up and set a few variables yourself based on your needs.
$customer = "PuTYouRDataBaseNameHere"
$maxDBsize = "15"
$NagiosStatus = "0"
$NagiosDescription = ""
